CLI to export text attachments
jfederkins
Hello -
I'm looking to export/import over 300 documents between 2 servers.
Probably going to do this via CLI batch files.
However, I do not see a way to export Text Attachments of nodes.  (not file attachments)
Any thoughts?
John
KaelLizak
(To:jfederkins)
Hi John,
Those are text attachments. I inserted SimpleExcel.xlsx into Requirement 21616 as an object on my test server.  Then I ran im extractattachments --issue 21616 --field="ALM_Text Attachments" which pulled SimpleExcel.xlsx  into the current directory.
Kael
Kind Regards,
Kael Lizak
KaelLizak
(To:jfederkins)
Hi John,
Take a look at CS131797.
Kael
Kind Regards,
Kael Lizak
Nope, that's for File Attachments.
I'm looking for ways to extract OLE attachments and images from the text field.
The filenames for OLE attachments and some images at least show up in the Text Attachments field.
But I don't think there's anyway to get them out.
KaelLizak
(To:jfederkins)
Hi John,
Kael
Kind Regards,
Kael Lizak
