Time units ns and ps in Prime - a bug?
ValeryOchkov
24-Ruby IV
I would like to use in my Prime-sheet time units ns (nano-) or ps (pico-) from the list of built-in units but:
Is it a bug?
(To:ValeryOchkov)
Found it.
The unit system is set to CGS. If you set it to SI, ps and ns are defined
No problem here with Prime 3.0.
I can type the units manually or chose them from the Units menu - they always work as expected.
Hi Valery, Werner.
It's a bug in 3.1, I have ns and ps undefined too.
Best regards.
Alvaro.
(To:ValeryOchkov)
In my Prime 3.1 express  the 'ps' works, and can be chosen from the units menu.
Open please the attached Prime 3.1 sheet with undefined ns and ps
When I open new sheet - all is ok with ns and ps.
When I open attached sheet - problems with ns and ps.
(To:ValeryOchkov)
Found it.
(To:LucMeekes)
And YES it's a bug...PTC, because even in a CGS system, ps should be allowed (as should 'fs', 'as' and below).
And it's a bug even more because ps is offered from the units table, also when the units system is set to CGS.
What units do not work in CGS?
What is a logic here?
(To:ValeryOchkov)
What's the logic in a bug?
