Hi all,
I am looking for a way to pass an additional argument to my custom worker. The main task that I want to achieve is to create a different output format based on user publishing params (Output Options). I uploaded an publishing rule xml containing two param-set
<param-set name="Create PDF">
<worker name="type">pdf</worker>
</param-set>
<param-set name="Create X_T">
<worker name="type">x_t</worker>
</param-set>
<publish on="create-representation" param-set="Create PDF"/>
<publish on="create-representation" param-set="Create X_T"/>
Now the user has the ablity to select between the two publishing options. On the worker machine (separate windows machine with worker daemon and generic worker) I would like to somehow get the "type" worker argument and pass it to the batch, or write it to the .in file. How could I achieve this?
Thx,
Tamás
