State does not change if a shared requirement changes
odiop-2
7-Bedrock
Hello all,
Could someone help
- one shared a requirement of document 1 in document 2.
-        One reviewed the requirement in the document of 2 and sets the state to released or review.
-        If one changes the requirement in the document 1, then the requirement in the document 2 changes automatically.
-        The state in the document 2 remains on released or in review.
-        Since the text changed we would like to have the state in the document 2 to jump back to in progress like in the document 1. Otherwise the developer will not be aware of the      changes in document 1
Is there a way to implement it without using email notification?
Oumar
Hallo Oumar,
  the trigger fires on the item in which you are. Not on the second item (shared).
  Because states are item individual, you need a more complex trigger to handle this situation correctly.
  The trigger must look into ALL related (branched) items and check one by one, and update the state accordingly.
  It must be a script based trigger.
