Drawing Angle Dimension Not Clocked on Centerline
nallen-2
3-Visitor
Attached should be a screenshot of the issue I'm having getting a dimension to behave. I have selected to display the angle between features of a pattern, but it doesn't line up directly on the centerline of the hole. Any suggestions?
StephenW
23-Emerald II
(To:nallen-2)
I think you need to regenerate.  Green dimensions (in my color scheme) mean a dimension has been changed but the model hasn't been regenerated.
Once regenerated, you may need to update the sheet (depending on your config settings).
StephenW
23-Emerald II
(To:nallen-2)
Green shows up when I hover over dimensions, on my system Red is for that situation. Thank you anyway Steven, I found a solution.
I redefined the pattern to be patterned on a dimension rather than the axis and now the 60 degree dimension shows up shows up on the centerline.
Best, Nicholas
