Hi to all,
I design the propeller with Blend in the wing area and close to the hub the "reinforcement" with style an then i solidify the surface.
The automated silhouette curve does not close all the part as sown in pics. I have search to find a tutorial or some solution but i was not able to fix my problem.
There is someone to known how i fix this ?
There is a way to drawing my own silhouette curve ?
Thank in advance
Apostolis
Are all of the surfaces selected for the silhouette curve?
no only those regional to the shape, In the propeller_3 photo sows the the silhouette curve.
I attach to more photos with all curves and those i exclude. The dark blue curve witch connect the tow blade in the hub region i created with style
Can you attach the model so that we can look at it?
Here is a propeller we create in my aircraft surface modeling class except the proper way is to use Trajpar and rotate NACA sketch some
http://proetools.com/creo-surfacing-level-9-surfacing-aero-forms-using-creo/
Canto do this in SOLIDWORKS LOL
Bart Brejcha
