Any bridge between capital harness and Creo cabling?
i have schematic in capital Logic.I want to import this schematic in Creo 2.0 for create harness by using Network routing.
After creating network routing or 3D harness assembly i want import this 3D layout in capital harness for crating 2D layout.
Please help.
Please provide any plugging for crate .nwf file and .xml file.
Thank You
Amit
Mentor does offer a bridge to create a .nwf file from Capital Integrator. I do not know if they have one from logic since it needs to have each individual wire defined but I think it would need to be done with Integrator. Either way you will need to get a hold of Mentor for the bridge license.
