Conditional routing based on Document attributes
ipsomiadis
6-Contributor
Hello all,
I am trying to have a conditional routing in a workflow, based on a specific attribute of the routed document.
In the expression I use this:
//get the attributes of the document.
wt.iba.value.IBAHolder holder = wt.iba.value.service.IBAValueHelper.service.refreshAttributeContainerWithoutConstraints(doc);
wt.iba.value.DefaultAttributeContainer ac = (wt.iba.value.DefaultAttributeContainer) holder.getAttributeContainer();
if (ac != null) {
wt.iba.value.litevalue.AbstractValueView[] avalues = ac.getAttributeValues();
for (int i=0;i<avalues.length;i++) {
wt.iba.value.litevalue.AbstractValueView val = avalues[i];
if (val.getDefinition().getName().equals("contracttype")) IPselect= val.getLocalizedDisplayString();
break;
}catch(Exception e) { System.out.println("Caught Exception:" + e.toString()); }
Then in the OR I have put this:
result="IP_Yes";
if (IPselect.equalsIgnoreCase("Consulting")) result="IP_No";
if (IPselect.equalsIgnoreCase("Service Agreement")) result="IP_No";
The problem I have is that some times it gets the value from the document (thus "IPselect" has a value in the workflow) and some others not.
Any ideas?
Thank you in advance
John
ipsomiadis
6-Contributor
(To:ipsomiadis)
It is solved. I found the error.
Originally I was telling to check this:
                break;
So the if was break at the first attribute it was getting (any attribute). Obvisously it was not the one i wanted. So I have put the break inside like that:
                if (val.getDefinition().getName().equals("contracttype")) {
                break;
So now it will check all the attributes, and it will stop when it will get the "contracttype".
John
7 REPLIES 7
Thank you for your comment.
The problem is that when the process run, sometimes I get the value of the attribute and sometimes not.
John
ipsomiadis
6-Contributor
(To:ipsomiadis)
                break;
                break;
John
Good for:
- keeping all brain cells really busy and working hard
- keeping us all humble
How good you feel when you find the problem seems to be in proportion to how hard it is to find the problem.
BenPerry
(To:ipsomiadis)
Ioannis Psomiadis‌,
You may want to consider switching over from wt.iba.value.IBAHolder to com.ptc.core.lwc.server.PersistableAdapter.  I think your code is being deprecated.  And the new code is fewer lines.  Check it out in the context of the other posting:  Re: PBO Attribute captured in a workflow
doc = (wt.doc.WTDocument)primaryBusinessObject;  // you can skip this - you already instantiated "doc"
com.ptc.core.lwc.server.PersistableAdapter obj = new com.ptc.core.lwc.server.PersistableAdapter(doc,null,null,null);
obj.load("contracttype");
IPselect = (String)obj.get("contracttype");
ipsomiadis
6-Contributor
(To:BenPerry)
Happy New Year Ben,
Thank you for your tip. I will test it in our development environment and I will let you know.
John
ipsomiadis
6-Contributor
(To:BenPerry)
Hello Ben,
I have tried to use the persistable adapter in a new promotio request workflow.
the code is as per below:
try {
wt.epm.EPMDocument doc =  (wt.epm.EPMDocument) primaryBusinessObject;
obj.load("com.bicworld.Type");
ditatype = (String)obj.get("com.bicworld.Type");
The ditatype nevertheless in the workflow is empty. it does not get the value of the object.
Spelling is triple-checked 🙂 and i cannot understand why is that happening.
after the robot, i have the conditional expression:
if (ditatype.equalsIgnoreCase("BOM Engineering")) result="Engineering";
if (ditatype.equalsIgnoreCase("BOM Package")) result="Engineering";
if (ditatype.equalsIgnoreCase("Design Visual")) result="Design";
if (ditatype.equalsIgnoreCase("Mechanical Properties")) result="Engineering";
if (ditatype.equalsIgnoreCase("Package Material")) result="Package";
if (ditatype.equalsIgnoreCase("Part Material and Masterbatch")) result="Engineering-Technical";
else result="KDM-QA";
but it is always selecting the KDM-QA branch of the workflow.
any ideas?
