I cannot run PTC CREO 3.0 M070 on my apple macbook pro runing windows 10. Here is the traceback.log information:
The trace creation timestamp is: jeu. déc. 08 11:39:19 16
The executable build timestamp is: ven. sept. 25 00:24:06 15
The datecode is: NA
The pro machine type is: NA
The process ID is: NA
The traceback type is : CRASH
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 3644.
I allready try some help online:
1) It's supposed to be the graphics card but I juste Update the driver
2) I change the config.pro file at the adress. C:\Program Files\PTC\Creo 3.0\M070\Common Files\jlink\jlink_appls\jlink_param from:
DISPLAY SHADE
DATUM_DISPLAY NO
AXIS_DISPLAY NO
DATUM_POINT_DISPLAY NO
DATUM_POINT_TAG_DISPLAY NO
SPIN_CENTER_DISPLAY NO
DISPLAY_COORDINATE_SYS NO
TOL_DISPLAY NO
To
DISPLAY SHADE
DATUM_DISPLAY NO
AXIS_DISPLAY NO
TOL_DISPLAY NO
ENABLE_OPENGL_FBO NO
DO YOU HAVE AN OTHER IDEA ?!?!!??!?
