Hi Eveyone,
Can anyone help me in How to add Config option "ap214_dis" in 'step_export_format' config in the config.pro file.?
In my 'step_export_format' config option has only "ap214_is"
Somebody suggested me "ap214_dis" option is used to get proper assembly and part surfaces and may avoid junk files
in the exported 'step' files.
My exact problem is when i converted assembly in to a 'step' surface format,
Those files are having lot of junk files when opening in 'ALIAS' software.
Can anyone suggest to proper assembly step file(surface) conversion options to support alias software?
Thanks in advance
uday.
