I'm new to using this software and although i have already managed to do this once now i can't.
I have the 3D model with the connectors and i have already routed the cables but when i try to make a manufacturing harness and try to assemble the components (connectors) the "assemble" and "Assemble All" options are greyed out.
Do you have any ideia why?
Thanks you
I would guess your connectors are not Designated as connectors, therefore manufacturing thinks all components have already been assembled, so those options grey out.
That or do you have the harness flattened to a point where the connectors should be assembled?
Thank you for your response @JeffRoeber. I actually had Designated them as connectors but was creating them after creating the harness. That was the problem.
Thanks once more
Good day Jose',
A Jive tip for @ mentioning (which is a great idea).
To ensure the person sees your mention, the correct format is @firstname_lastname for example Toby Metcalf
Thanks for participating!
Best,
Toby
