Please share your experience of New version of PTC Creo 4.0 with features and models. And also tell more about ur produce and which version u will recommend to people.
Make sure in your mouse settings the middle wheel is set to "Middle Click" or "Middle Button" or something to that effect (depending on your particular mouse settings). This is all assuming you are on something prior to Windows 10 as there have been other issues that deal with the Mouse and Windows 10.
Hi Leo,
Did Shane's response help answer your question? If so, please mark it as the Correct Answer, so other users, with the same query, can quickly find the solution.
Amit
You can just hold "CTRL+SCROLL BUTTON" then drag the mouse up and down to zoom, left and right to rotate.
VIJAY
