I want to know in which workspace(s), I have several, that a particular CAD object resides. I cannot locate any search criteria that would return my query?
Are you an administrator? I have a report that will show the workspaces that a CAD file resides. But I'm not sure how to attach it to my reply.
If you're not an admin, then perhaps your admins can import the report and expose it to the end users to run themselves. But it depends on security in your company. Maybe it is not permissible to see the objects in others' workspace.
Ben,
if you want to attach a file to this discussion you have to select Use advanced editor in the right upper corner when replying and then Attach in the right lower corner (see attached images).
Thanks Marco. I switched to advanced editor, but I was only looking on the toolbar. Thanks for the tip.
