I created an appendix at the end of my bookmap. Unlike all the other topics in my book, the appendix topic title does not show up in the TOC. How do I fix this?
Sorry if you've already figured this out! I've just solved this one for myself...
I think this is the solution:
Select the TOC in the Table of Contents page in Styler.
Select 'Customize Title Contents' button.
Check the box for the 'title in appendix' level (or your own named style).
Select the adjacent 'Add' button.
Select the 'Edit' button for the Text box.
In the Custom Text window: Insert > Element Number & Insert > Element Content.
Select File > Apply and Close.
Cheers.!
