What Happened to my Negative sign
ppal
17-Peridot
Pic.pngI have an output issue with mathcad Prime. I am missing a negative sign. I have attached PDF and actual Prime and mathcad files.
ppal
17-Peridot
Yes. It is a bug. Worksheet sent to Mathcad Developer by our maintenance service  provider for resolution.
(To:ppal)
You have a point at least. This is what Mathcad 11 shows:
And this is Prime 3.1.
In both cases, the second element of the result array has a negative imaginary part. But if you change the formatting of the result to 'decimal', it changes to:
And the imaginary part of the second element is suddenly positive. Of course this does not happen in Mathcad, this only occurs in Prime...
It's a BUG!
Work-around: don't format your results to decimal.
ppal
17-Peridot
(To:LucMeekes)
From RD’s feedback, Mathcad Prime 4.0 had resolved the issue. And Prime 4.0 will release in the end this month.(Feb. 2017)
-MFra-
21-Topaz II
(To:ppal)
Hi ,
You could proceed  first defining the formulas and then providing the numerical values. See the following image:
ppal
17-Peridot
(To:-MFra-)
Why?
24-Ruby V
(To:ppal)
Seems that you found a bug in Prime!
It does not affect calculations but only(?) the display of results.
Whenever the real part is so small that it would be displayed as zero with the given precision, its not displayed at all (which is kind of OK) but the sign of the imaginary part is lost.
ppal
17-Peridot
ppal
17-Peridot
(To:ppal)
24-Ruby V
(To:ppal)
Thanks for the information.
