Dear All
I need to understand if is possible enable the worker to publish also the DXF format for the Drawing but only under parameter condition.
My idea is define a boolen parameters on EPM Document like DXF_Publish TRUE/FALSE and the make the system
able to publish r DXF file if the above parameter was set TRUE.
Thanks to everybody have the solution
Beniamino
This is possible, I haven't tried this, but it should work
