We are happy to announce the new Windchill Customization board! Learn more.
Possible options to extract the CAD file information without opening in Creo.
HarikrishnanR
3-Visitor
Dear Experts,
Please let me know, Can we extract the CAD model "Parameter values" (Description, Material, and Revision etc.)  as well as  model "associated parts" information ( family table instances, Drawing numbers etc.) which is stored in “Shared network drives OR Local drives”.?
Note:
Information should be extracted by without opening the CAD model in Creo
Hari
"Share your knowledge. It is a way to achieve immortality.” - Dalai Lama.
This might be possible if the creo Workgroupmanager would work in the same way as the CATIA V5 WGM does. With the CATIA WGM for each Workspace-Object a XML-File is created. In this XML-File you have the complete Metainformation of the related CAD-Document.
In creo you have only one XML-File that contains all Metainformation from all CAD-Objects located in the Workspace. This file is located in your cache-directory and is named like ws.cache.<nr> (not one the ws.cache.content.<nr> Files). From this you can extract the needed Information.
To use this file you have to send the Files to your Workspace.
Markus
Thank you Markus!
One of my ex-colleagues wrote a toolkit program to read/write parameters without actually opening the file in Creo. However if I remember correctly, it still uses Creo in the background to read/write the values. If this is something you are interested, I can message you his contact details.
Hi Binesh, Thank you!
Could you please share your colleagues contact information to harikrishnan-r@hcl.com
Hari
