Hi all,
I have made a centrifugal pump in, CREO 2.0.using an in volute curve as a trajectory for the swept blends containing different sketches as profile for swept blend feature. Now I want to show these section profiles in drawing by sectioning them at the profile planes. But the problem is those section sketches are internal (i-e they are within the swept blend feature) which means they have no plane predefined for them as these sketches are normal to the trajectory. So do I have to define DTM planes parallel to the section profiles to use them as section view to show in drawings or is there any other way to section at those profiles without defining additional planes? (i am avoiding defining additional DTM planes as these will crowd my model tree and they will be there only for section view, and no other purpose)
