When trying to launch an analysis in creo simulate, I get a fatal error and Creo logs the following error:
The trace creation timestamp is: mer. mars 08 16:10:39 17
The executable build timestamp is: jeu. mars 24 11:14:53 16
The datecode is: 2016050
The pro machine type is: x86e_win64
The process ID is: 5500
The traceback type is : CRASH
The logger exit status is: 00003
The release is: 3.0
The external datecode is: M090
The product title is: Creo Parametric
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 5820.
Any idea to fix this issue ?
Thanks.
Hi Thierry,
There is not information in log about the exit. You may submit a case for PTC Tech. Support to review the issue.
