We need for assistance to export images files from Creo Illustrate Figure to any image extension (PNG, BMP, JPG) with transparent background.
Hi Higor,
It's not possible to export PNG or SVG, from Creo Illustrate, with alpha channel, so that the background of the picture is transparent.
Amit
This essential basic feature is absolutely needed.
We export images from Creo/View all the time, and have to manually remove the solid background from each image in Photoshop for further use. This is not only extremely time-consuming, but also leads to poor, pixelated quality of the edges.
The lack of this feature has been stated for many years all over the Community and Ideas pages.
Something has to finally be done about this.
