Creo internal variable names and assignment to parameters
cadcam
Dear All,
    Just looking at enhancing some of our drawing templates and possible automation of simulate results.
     1) Up to now we have manually entered some data into tables on drawings and some automatic.
I was looking to automate the inclusion of some material data etc
   if I set parameter MATERIAL_TYPE  = material_param("PTC_MATERIAL_DESCRIPTION")
   in a relation I can use it in notes and tables etc. However if I chnage DESCRIPTION for NAME or DENSITY it doesn't work.
    assume they must have another internal name. Where can I obtain a authoritive list of internal parameter names that can be used in relations etc.  and any limitations on their use
rmcboaty
7-Bedrock
(To:cadcam)
llie
16-Pearl
(To:cadcam)
Try these relations as I am working on implementing them at our company.
TITLE = PTC_COMMON_NAME
CAGECODE = PTC_ORGANIZATION_ID
PARTNUMBER = REL_MODEL_NAME
BenLoosli
23-Emerald II
(To:llie)
Cage Code is a numeric number issued by the US government as a supplier ID. Are you really using that as your PTC_ORGANIZATION_ID?
llie
16-Pearl
(To:BenLoosli)
Yes, PTC_ORGANIZATION_ID is the mapped attribute in Windchill for cage code and gets push into our files parameters.
cadcam
(To:cadcam)
Thank you for the feedback. I think I now have a solution to half my problem. What I wanted to do was to put the material name (+ properties) on a drawing in a table.  In the .mtl fles there are a series of properties, the names of which are available to use in relations. However the same parameters are not neccessarily defined for each material, depends on the source, and in particular NAME is not one. However you can add additional properties, so to get the material name to transfer I have generated a new field, e.g. for Brass
in brass.mtl add the lines
  Name = CUED_MATERIAL_NAME
  Type = String
  Default = 'BRASS'
  Access = Full
[NB Name doesnt have to start with PTC]
In relations add
MATERIAL_TYPE  = material_param("CUED_MATERIAL_NAME")
where MATERIAL_TYPE is a parameter defined in the start part
Then &MATERIAL_TYPE can be used in tables and notes on a drawing
Now to find out how to allocate the user's id to a parameter to put in drawings (2 & 3d)
BenLoosli
23-Emerald II
(To:cadcam)
User's id, you mean PTC_WM_MODIFIED_BY or PTC_WM_CREATED_BY?
cadcam
(To:BenLoosli)
Do these variables come from Windchill?
Currently relations (creo4) on my system doesn't seem to recognise them [we don't run WC]
I have a workaround whereby I can set the originator to the windows username automatically via a mapkey, but it does seem a little longwinded.
llie
16-Pearl
(To:cadcam)
These variables do come from Windchill.
