We are happy to announce the new Windchill Customization board! Learn more.
how can I abandon a running promotion request
thussong
3-Visitor
I have a running promotion request that I need to abandon or stop so that I can replace an approver with another approver.  My thought was to simply abandon the running workflow and start over.
BenLoosli
23-Emerald II
(To:thussong)
If you created it, just select the PR and delete it.
The files will be returned to their prior state.
Any admin can also do it.
d_graham
17-Peridot
(To:thussong)
If you're just replacing the approver why not simply edit the team?
if you have enough access rights:
promotion request action menu: "reassign life cycles", check "Use initial state of Life Cycle template" .
disclaimer: side effects are possible as you are about to terminate the original workflow.
