I have a part which is used multiple times in Assembly but in BOM weight of only one part is seen. Should I multiply with qty to get total weight? If yes how? If no then what else can be done?
Create a table relation of asm.mbr.pro_mp_mass * asm.rpt.qty.
Hi Swapnil,
You can get some further information on repeat region relations via the following Suggested Technique:
Suggested Technique for Using Report Relations to Control Repeat Region Parameters
Amit
