assistance to solve difficult integration in mathcad
gvalishova
i am  having difficulty with the integration problem.
i dont even know mathcad can solve it or not.@
Thanks in advance
-MFra-
21-Topaz II
(To:gvalishova)
Hi gvalishova,
the symbolic itegration presents some difficulties.
Some of us can't read Prime 3.1 or Prime 4.0 files.
So it may be a good idea to additionally attach a screenshot or pdf of the file.
Sure
(To:gvalishova)
Start by separating the x of the integration limit from the x as integrand, e.g. by defining your function W as a function of z instead of x:
-MFra-
21-Topaz II
(To:gvalishova)
Hi gvalishova,
Thanks a lot  F.M. for your solution
actually what i needed was W(x) - x relation. Can I use g(x) - x graph as W(x) - x in a given range?
and can you pls insert your solution in mcdx. because i have to find W(x) - x relation for different t0's
-MFra-
21-Topaz II
(To:gvalishova)
Hi gvalishova,
I have attached the requested worksheet.
Greetings
F. M.
