Windchill rename issue
sasaigoli
3-Visitor
How to  do mass renaming in windchill ?
hthakre
(To:sasaigoli)
  • Multiple unrelated CAD Documents cannot be renamed at one shot because there may be several dependencies which cannot be handled at one time.
  • Multiple CAD Documents can be renamed if they belong to an Assembly:
In "Commonspace":
  1. Click "Product" or "Library" > Folder
  2. Select a top level CAD Document (i.e. top level assembly or drawing)
  3. Select Actions > Rename
  4. Include dependents
In "Workspace" (works for new objects only):
  1. Select a "Workspace"
  2. Select objects
  3. File > Rename
For more information, refer to : http://www.ptc.com/cs/help/windchill_hc/wc100_hc/index.jspx?id=CADxFileMenuObjRename&action=show
Gagan
7-Bedrock
(To:hthakre)
Hello Harshal
If all the parts are not belongs to the one assembly , is it possible to do the mass rename ?
I there any option to add those part to base line or any collector and then do the rename ? to my knowledge it is not possible even i tried any way .
If you know any method to do this please let me know .
Gagan
JeffZemsky
17-Peridot
(To:Gagan)
Yes - you can support rename from Search as well.  you can search for multiple part numbers with a ; separator
Hello Jeff
I agree that we can do the multiple search by using separator , But even in the search result it is not possible to do the mass rename , am i rite?
If possible ,Could you please explain me how ?
Gagan D
JeffZemsky
17-Peridot
(To:Gagan)
Gagan Doreswamy‌ - Rename is available from search.  I forget which release it was supported in but it is available
