Is it possible to run script from a c# application?
sdumon
Nowaday, I build c# UI and application to answer to designer's needs.
In order to keep our application as independant as possible, i would like to run scripts contained into a given model from those application.
Do any elements exist to do so?
sdumon
(To:sdumon)
Hi Kael,
Sorry for the delay.
I finally found a solution wich maybe could help the comunity. This solution is not as simple as I expected but works fine.
This is what i have done :
1. get the script object present in your model (A), especially the script text.
2. concat the script text with the following script (B)
Dim CurrentObject, Dictionary
Sub Main()
  On Error Resume Next
  Set Studio = CreateObject("Studio.Editor")
  Set Projects = CreateObject("OMTE.Projects")
  if Err.Number > 0 then
  Studio.DisplayOutputWindowMessage Err.Description & " " & Err.Source & vbcrlf
  Err.Clear
  end if
  Call Studio.OpenModel("%_PROJ_NAME_%")
  modRef = Studio.GetCurrentModelReference()
  Set Project = Projects.Item("Reference", modRef)
  Set CurrentObject = Project.ItemByID("%_PKG_ID_%")
  Set Dictionary = CurrentObject.Item("Dictionary")
  Err.Clear
  else
  if RunUtilityUI then
  Project("Transaction") = "Begin"
  CommitUtility
  Project("Transaction") = "Abort"
  else
  Project("Transaction") = "Commit"
  end if
  end if
  end if
End Sub
Call Main()
     This script open the model in wich the modification should be done, call the utilityUI method of the retreive script text.
3. Once the concatenation is done, save it into a temporary vbscript file.
4. Create a process wich execute the CSCript exe, and execute the temporary script previously created.
5. Finally, observe the modifications.
This method is a complex one but allow to execute a given script from outside of a model.
Hope this could help.
KaelLizak
(To:sdumon)
Hello Stephane Dumon‌,
I don't have a direct answer for your question, but I'm wondering if this information might be helpful?:
Which release of Integrity are you using?
Kind Regards,
Kael
Kind Regards,
Kael Lizak
sdumon
(To:sdumon)
Hi Kael,
Sub Main()
  Err.Clear
  end if
  Err.Clear
  else
  CommitUtility
  else
  end if
  end if
  end if
End Sub
Call Main()
