Hello All,
My Product having Assemblies with Top & sub levels and i need to extract all assemblies to mulitple spreadsheets as bulk? could you please suggest any way to extract assy's?
Srini
Hi Srinivas Morla,
If format doesn't matter (you said you need spreadsheets ) and if you are ok viewing with third party tools, then you can take a look at this:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS191103
Shirish
