Is it possible to have the ISO tolerance tables always loaded(avoiding the step of retrieving the tables) ?
With this I can reduce a step in drawing process increasing the productivity.
I am not sure what note are you creating in a drawing.
Load ISO tolerance tables must be done in model, see following picture.
MH
MH
Thanks for your help.
The tolerance definition is already in ISO/DIN. But when i want to create the note on 2D draw i have always to retrieve the tables. I want to know if there's a way on config.pro or in other file to have the tables always available.
MH
Ok, I always do that as you shown on the picture before.
For example, i'm a designer easily a machine in my projects have more than 100 parts, do i have to do this 100 times or is there a way to do it just once.
YES, you have to do this 100 times.
MH
