Creo 4.0 unable to start due to (-97) The desired vendor daemon is down error
SandeepKadam07
Dear all,
I have recieved latest license file for creo 4.0. I am able to run creo 2.0 & creo 3.0 using that license file.
But only at the time of creo 4.0 launch getting this error.
it looks like FLEXnet is not running on your PC ...
MH
Martin Hanák
Dear Martin,
Please find below screenshot. I always ensure if flexnet services is started or stopped.
unfortunately checking the status of Flexlm Service 1 in Services dialog box is not the right way, how to check if license manager is running properly on your PC.
1.]
You have to check running processes ... can you see ptc_d.exe process running ?
What other processes can you see ... lm_admin.exe, lmgrd.exe ?
2.]
You have to check the contents of FLEXnet log file ... it can contain error messages...
Questions:
a.]
What FLEXnet version is installed on your PC ?
b.]
What "combination" do you use ?
lm_admin.exe + ptc_d.exe ???
-OR-
lmgrd.exe + ptc_d.exe ???
MH
Martin Hanák
Dear Martin,
Please see below attached log file for details
in C:\license.txt you can see the following error message:
File not found. C:\Program Files\PTC\FLEXnet Admin License Server\i486_nt\obj\ptc_d.exe
I guess that the above mentioned path to ptc_d.exe is set in license.dat file.
i486_nt is related to 32-bit version of FLEXnet.
In case that you have 64-bit installation, you have to use C:\Program Files\PTC\FLEXnet Admin License Server\x86e_win64\obj\ptc_d.exe path.
MH
Martin Hanák
