Recompiling a WF5/CEpro5.o toolkit program to Creo 3. The particular program runs as an unmanned batch system. The program registers Windchill in the User_Initialize function. Now that I compile the code to Creo3 I just get a flashing window when the ProServerRegister command is used. Its the exact same as the issue reported in the unresolved CS246648 - which shows a video of the behavior. Their example is slightly different because a user is clicking a button to initialize the toolkit registration, but same thing.
Is anyone in any version of Creo3 able to perform a ProServerRegister? If so whats your datecode?
This code has worked for years.
tkerr = ProBrowserAuthenticate(username, password); returns 0 no error.
tkerr=ProServerRegister(serverAlias, codebaseURL, WINWName, &aliased_url);
I end up with a fix for this. PTC notified me it was fixed in Creo 3.0 m120. Not just running in m120, but I had to recompile as well. It at least stopped the flickering window. It appeared to work but would only connect to the last used workspace regardless of which workspace I specified and ProServerRegister would return a -5 (found). To solve that issue i have included a line in my startup file to rename the .svr_mgr_db3.fldx file (WC cache file that contains your past windchill connection info). ProServerRegister now will register any specified workspace.
Hello Mark
What is the compiler version you've used? CREO 3 Supports Visual C++ 2012 (VS 2012 Compiler).
I Don't have CREO 3 but in CREO 2 ProRegisterServer() working fine for me.
I am using Visual C++ 2010 compiled DLL into Visual Studio 2015 C# Project (Creo 2 Supports Visual C++ 2010 Compiler only)
I am using the VS 2012 compiler.
Issue still not solved. still an spr at PTC.
Hi @msteffke
I have some bad experiance on same code works in C Programming (.c) files yet it not works on C++ Programming (.cpp). You may try with c. This may not a solution but a suggestion
Thanks pkannan. I am writing in plain C though.
Hi Mark,
was it solved in M120? I just recompiled a Creo2 toolkit program in Creo 3 M140 and the flickering window pops up.
Kind regards,
Jan
In my opinion it is not fixed. I never could get it to hook to any workspace other than the last WS. ProServerRegister would return a -5 (found). To solve that issue i have included a line in my startup file to rename the .svr_mgr_db3.fldx file (WC cache file that contains your past windchill connection info). ProServerRegister now registers any specified workspace. Its a workaround, but I had to move on to other things.
The line I used in my proe1.bat file is:
RENAME %PTC_WF_ROOT%\.SSAPPD\ServerMgr\.srv_mgr_db3.fldx old.srv_mgr_db3.renamed
