create popup menu with button clik
ss-10-11-12
can anybody help me how to create popup with button click.The popup must contains label,TextFeild and button.
sjuraj
(To:ss-10-11-12)
Do you mean java (j-link) ?
sully7
(To:ss-10-11-12)
Hi Sangavi,
A couple of quick questions
  • What version of Creo are you using?
  • What API are you using?
  • By "popup" - do you mean a "PopupMenu" as in what happens when you "right click" somewhere? or do you mean just a "dialog box" with a button?
If you are looking for an actual "Dialog" box - I would highly recommend using Creo's "UI Editor" to help create your dialog. It is quick and easy to create a dialog with the layout you want, and it will even auto-generate C++ code for you.
On the other hand... if you are using ProToolkit, and only need a dialog box with some "standard" buttons, then ProUIMessageDialogDisplay should do the trick.
"Standard buttons" include:
typedef enum pro_ui_message_button
  PRO_UI_MESSAGE_ABORT = 0, /* Abort from the appln */
  PRO_UI_MESSAGE_RETRY = 1, /* Retry the step */
  PRO_UI_MESSAGE_IGNORE = 2, /* Ignore the event */
  PRO_UI_MESSAGE_CONFIRM = 3, /* Confirm the event */
  PRO_UI_MESSAGE_YES = 4, /* confirm the event */
  PRO_UI_MESSAGE_NO = 5, /* disagree */
  PRO_UI_MESSAGE_OK = 6, /* acknowldge */
  PRO_UI_MESSAGE_CANCEL = 7 /* disacknowledge */
Some example code (NOTE: I haven't tested this - so hopefully it works haha):
ProError hello_world {
  ProError err = PRO_TK_NO_ERROR;
  ProUIMessageType message_type = PROUIMESSAGE_INFO;
  ProUIMessageButton *buttons;
  ProUIMessageButton ok_button = PRO_UI_MESSAGE_OK;
  ProUIMessageButton cancel_button = PRO_UI_MESSAGE_CANCEL;
  err = ProArrayAlloc(0, sizeof(ProUIMessageButton), 1, (ProArray*)&buttons);
  err = ProArrayObjectAdd((ProArray*)&buttons, -1, 1, &ok_button);
  err = ProArrayObjectAdd((ProArray*)&buttons, -1, 1, &cancel_button);
  ProUIMessageButton user_picked_this_one = PRO_UI_MESSAGE_CANCEL; // set an initial value just incase
  err = ProUIMessageDialogDisplay(message_type, L"Hello World", L"Hello, World!\nThis is a popup.", buttons, ok_button, &user_picked_this_one);
  if (err == PRO_TK_NO_ERROR && user_picked_this_one == PRO_UI_MESSAGE_OK) {
    return PRO_TK_NO_ERROR; // hooray! ^_^
  return PRO_TK_USER_ABORT;
"pfcSession::UIShowMessageDialog" is the OTK (C++) equivalent.
Let me know if this works for you, and feel free to PM me if you have more questions.
James Sullivan
CadActive Technologies
President & Founder
CadActive Technologies - www.cadactive.com
