Hello
I don't know if you are able to give this kind of support, if it is not possible, please I'm sorry, maybe you can forward this request to any other person that can help me.
I've just installed pro-e 4.0 and I'm trying to include an asm with .stp extension in my asm but the size or resolution are totaly different.
I fixed "units" information on model properties, but it doesn't work...
All the parts that I drawed are ok, but when i try to include another that I didn't make on pro-e I have this problem:
See below:
This purple part is the one that I need to assembly in my asm
tks a lot
