Hi CREO users,
the option "web_browser_homepage" is used to specify the path of home page for internal Creo browser.
Do you know if it's possible to manage a specific zoom value for this page in automatic way ?
Thanks in advance
Pier
I think, this is not possible within Creo. You can however create mapkey that would run script which sets your page and than virtualy press key CTRL + PLUS SIGN to zoom the page, but it is not so clear way but may work.
Thank you
but the mapkey unfortunately doesn't work !
Have a nice day.
I have tryed to make the script but there is problem the script always zoom page even when page is already zoomed. You will have to zoom your page manually or use toolkit up which can remember if the page was zoomed.
Yes
the roll middle button works if you zoom manually.
The point is to automate the operation.
Mapkey could be a good compromise
Better if it's possible to define a specific value of zoom ( i.e. 100 % ...)
Thank you anyway
CTRL + 0 sets your zoom to be 100%.
I have the same problem in Creo 3... but from my experience, this seems to be fixed in Creo 4.
In terms of "normal IE" operation, if you load up your Internet Options, and go to the 'Advanced' tab, there is a checkbutton to "Reset Zoom on new windows and Tabs"
That fixes my NORMAL IE tabs... but doesn't seem to fix the embedded browser sadly. I'll investigate more tomorrow though
James Sullivan
So, this is what I've gathered so far (using Creo 3 M110 as my test environment):
Again... all of this seems to have been fixed in Creo 4, but its at least good to know what your options are!
Hope this helps,
James Sullivan
Many thanks James
Ctrl+0 is a good solution
even if it's not possible to use a CREO mapkey.
Bye
Pier
