Hello
Is there any way to extract the measures data to a csv file? Also, when I plot out the measures, is there away to change the axis from linear to log?
Rich Hilson
Richard
You can save a graph as an excel file (file, save as, select excel in the box right below)
You can change the axes like this: Format -- Edit
change each of the axes to log scale
Hope this helps
Kind regards
Erik
Thank you so much.
You have been a big help.
Richard Hilson
