how do I re install Creo Elements direct on my laptop?
Are you having problems with the install? Do you have access to PTC's download site? Do you have a valid license?
Tom
Run the installer again.
Either from the Media (CD, DVD etc.) - or, if you have installed the Software already,
go to Software -> select CED Modeling -> and you get:
Hope this helps.
