Anybody explain me.I am a beginner in protoolkit
I can only give you an exmple in J-link:
Session session = pfcGlobal.GetProESession();
Model model = session.GetCurrentModel();
String modelName = model.GetFullName();
session.UIShowMessageDialog(modelName, null); // this brings default Creo ui dialog with name of current model
Thanks.I need protoolkit coding
I do something similiar what your asking. ParamValString is a function I have that gets the parameter value for a string param.
Basically I print my info to a text file, then open the text file using ProInfoWindowDisplay.
You could use ProUIDialog functionality as well for a fancier method. I just found this method very simple to do.
strcpy(mypar, ParamValString("NAME", modelitem));
fprintf(fp," Parameter information for %s\n",mypar);
fprintf(fp,"------------------------------------------------------------------\n");
fprintf(fp," DESCRIPTION: %s\n",ParamValString("DESCRIPTION", modelitem));
fprintf(fp," NAME: %s\n",ParamValString("NAME", modelitem));
fprintf(fp," MATERIAL: %s\n",ParamValString("MATERIAL", modelitem));
fprintf(fp," UNIT_OF_MEASURE: %s\n",ParamValString("UNIT_OF_MEASURE", modelitem));
ProStringToWstring (wfname, "c:\\temp\\ViewPars.txt");
status = ProInfoWindowDisplay (wfname, NULL, NULL);
Hi Keerthana,
I posted this a few days ago - it may help: Re: create popup menu with button clik
Mark's code is definitely useful ( I actually am a huge fan of the ProInfoWindowDisplay ), but without having the custom "ParamValString" method, here's another method that may work for you:
ProError creoTest() {
ProError err = PRO_TK_NO_ERROR;
ProMdl current_model;
ProMdlName current_model_name;
err = ProMdlCurrentGet(¤t_model);
if (err != PRO_TK_NO_ERROR) { return err; } // in case you don't have a model open
err = ProMdlMdlnameGet(current_model, current_model_name);
ProUIMessageButton *buttons; // an array of buttons
ProUIMessageButton ok_button = PRO_UI_MESSAGE_OK;
ProUIMessageButton cancel_button = PRO_UI_MESSAGE_CANCEL;
err = ProArrayAlloc(0, sizeof(ProUIMessageButton), 1, (ProArray*)&buttons);
err = ProArrayObjectAdd((ProArray*)&buttons, -1, 1, &ok_button);
err = ProArrayObjectAdd((ProArray*)&buttons, -1, 1, &cancel_button);
ProUIMessageType message_type = PROUIMESSAGE_INFO;
ProUIMessageButton user_picked_this_one = PRO_UI_MESSAGE_CANCEL; // set an initial value just in case
err = ProUIMessageDialogDisplay(message_type, L"Current Model Name", current_model_name, buttons, ok_button, &user_picked_this_one);
if (err == PRO_TK_NO_ERROR && user_picked_this_one == PRO_UI_MESSAGE_OK) {
return PRO_TK_NO_ERROR; // hooray! ^_^
return PRO_TK_USER_ABORT;
NOTE: If you are using Creo 2 - then you will need to use "ProName" instead of "ProMdlName", and "ProMdlNameGet" instead of "ProMdlMdlnameGet".
James Sullivan
President & Founder
Thanks sir. Now It work.
