Hi!
I have a BID-WID diagram in schematics, and I have to copy (with cut) a part of the wiring to another sheet. When I do this all artifacts lose their co shapes in the wiring. So I've tried to reassign the shapes, but it gives me various errors, and I so I cant make it happen.
Block diagram:
The part of the block diagram, it contains block and also group artifacts too.
The WID of it:
I cut this (ctrl+x, or right click CUT, doesen't matter) to another sheet.
If I try to reassign the shape of the wiring connector J-03 to J-02 (picture shows J-02 on wiring because it was taken before the cut-paste) it gives me the following error message:
If I try to do the same with the heater element the error message is the following:
But If I try the same on the block diagram with the connector J-03 it works (it doesn't work with the block artifacts like this neither), just the name won't be the same as before, and that's not acceptable.
I had this problem before, then I had to add the connectors again (in case of a 37 pin D-SUB connector it's not so easy, reordering the members one by one, not the best thing to do).
Do you have any idea why this happens? Thanks!
Laszlo
