Below is a tip for those of you trying to mirror a part with family instances on the same drawing. The issue came out at an internal discussion, and was found worth sharing out – probably some of you will found it useful.
Imagine you have a part_a.prt with family table, just 2 instances : part_a_inst1.prt & part_a_inst1.prt. And you have them all put on a different views on the same drawing, same or different sheets – for whatever purpose you need it.
Now you need to Mirror this part in a way drawings will be “smartly” copied and adjusted to a new mirrored objects. It does work if you use option rename_drawings_with_object = part (or “both”) and use “similar name convention” for part and drawing - and can potentially save you quite a time.
However, the known limitation is that upon file / mirror operation, Creo strips family table from the new mirrored part. So drawing will be copied, and generic model will be replaced in drawing with a name of mirrored object. But since other 2 instances will not be copied – drawing retrieval will be aborted (as in case of missing drawing model).
Trick proposed below can help you work this around and still have you drawing fully mirrored.
In case you mirror by "geometry only" method this will also work, though resulting views will be much less meaningful - since this way of mirroring does not preserve any feature information so mostly all annotations will be lost.
Hope this will be helpful in some cases,
Vlad
