I am integrating Windchill 11.0 M010 with MKS integrity 10.9. I got stuck in field mapping hence unable to locate Windchill parts in Integrity and corresponding Integrity Documents in Windchill.
What can be the solution for this?
Hello @cagarwal,
Have you taken a look at CS243157: How Should the Field Mappings be Configured in the PTC Navigate Manage Traces App? That's going to give you a general idea of what's required. If you've read that, and it hasn't helped, can you let us know what types in Integrity Lifecycle Manager you're doing a mapping against? If this starts getting into significant detail, you will probably need to open a case for this.
Kind Regards,
Kael
