Dual Dimensioning Exceptions
scarey
How do I exclude a tapped hole designation on a drawing from having a metric equivalent applied when dual dimensioning is turned on in Creo Parametric 3.0
BenLoosli
23-Emerald II
(To:scarey)
Properties and turn off dual for that one dimension.
StephenW
23-Emerald II
(To:scarey)
Dual dimensioning is all or none in Creo 3, Unless there is something hidden or a trick.
