VB API program to import neutral file
ms-6
6-Contributor
Hi all,
I am trying  to import neutral file(igs) using api, I get error as INVALID VARIANT TYPE
Try
            session.ImportNewModel("C:\4021B30hs.igs", EpfcNewModelImportType.EpfcIMPORT_NEW_IGES, EpfcModelType.EpfcMDL_ASSEMBLY, "vv", "")
Catch ex As Exception
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
End Try
sjuraj
(To:ms-6)
I think your last parameter is wrong. It should be LayerImportFilter or null not empty string.
