Animation Time Domain - Frame Rate option locked.
ddelacruz
I am trying to run an animation of the mechanism analysis for my Assembly. I want to change the frame rate on the Time Domain settings to increase the speed of the animation but it is locked and I am unable to change it. Below is a screen capture of the dialogue box. I would be really grateful for any help or suggestions to fix this problem.
Kind Regards,
Dency
mbonka
(To:ddelacruz)
Hello Dency Dela Cruz
- default way is select from po-up menu
- but in your picture it is locked
Do you have installed proper "modules"?
See FILE - HELP - SYSTEM INFORMATION
You need:
     A) Design_Animation
     B) Mechanism_Design*
Milan Bonka
