Can anybody explain what are the benefits & limitation of Toolkit Synchronous & Asynchronous Application?
PARTHIBAN_K
I Just want to know whether to select synchronous & asynchronous application for my Project.
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
@PARTHIBAN_K
By now you must have made the decision but just thought to share information which I have.
I hope in future it helps somebody.
Link below helped me understand the basics:
Page# 12, 13
http://www.ptcuser.nl/conf_14/presentations/1-2-Customizing%20and%20Automating%20PTC%20Creo/APIs-2014.pdf
Plus per information which I came across is :
synchronous (in session) or asynchronous (without creating a graphical session of pro).
Warm regards,
Madhavi
