10 Replies Latest reply: Oct 21, 2010 11:15 AM by Liv RSS
    nth term formulas
    Copper
      I am trying to help my daughter in her Geometry I class. Is there a formula for finding the nth term in a sequence? My oldest daughter, BA degree, and myself have tried to figure out the nth term. One problem looks like this:
      Find the nth term of
      6, 25, 56, 99, 154
      We have NO idea on how to start on this one.
      Any help will be appreciated. Thank you
        • nth term formulas
          superres Silver
          >this:
          > 6, 25, 56, 99, 154
          >start on this one.
          >Thank you
          Graphing such things usually helps. I did it in Excel. If you do that, you'll see that it's almost perfect fit for a series of squares of the first 5 non-zero integers multiplied by a scaling factor of 6. So, if you subtract that from the original numbers, you get the first 5 integers, e.g., those guys start at 0.
          Therefore, the next number should be 6*62+5
          and the general form is:
          6*n2+(n-1) where n starts at 1
          or
          6*(n+1)2+n where n starts at 0
          TTFN,
          Eden
          • nth term formulas
            Copper
            TO TOM:
            I can figure out the next numbers, what is the nth term equation e.g.: 2n(n-3) that will get me the correct next number??
              • nth term formulas
                Silver
                See my reply to your other thread. You can plug in the differences to the general formula and get the expression 6n²+n-1. You can factor that into (2n+1)(3n-1), although I don't see that as much of an improvement.
                � � � � Tom Gutman
                • nth term formulas
                  superres Silver
                  On 10/26/2005 5:13:31 PM, butter wrote:
                  >TO TOM:
                  >number??
                  the second difference of 12 tells you that the n2 term is multiplied by 6. It's essentially the derivative of the power term in the equation. If you then subtract 6x2 from each term, the resultant is linear term series whose 1st difference is 1, so there is a 1*n term. subtract that from the original series leaves the constant term.
                  TTFN,
                  Eden
                • nth term formulas
                  Silver
                  There is no fully general method. Much depends on the particular series. But a useful place to start is to calculate the differences:
                  6, 25, 56, 99, 154
                  19, 31, 43, 55
                  12, 12, 12
                  The second differences are constant, so the numbers can be represented by a quadratic equation. But there is no need to actually work out the quadratic -- the table of differences can be extended by adding a fourth second difference of 12:
                  6, 25, 56, 99, 154, 221
                  19, 31, 43, 55, 67
                  12, 12, 12, 12
                  � � � � Tom Gutman
                    • nth term formulas
                      Copper
                      >6, 25, 56, 99, 154
                      >19, 31, 43, 55
                      >12, 12, 12
                      >difference of 12:
                      >19, 31, 43, 55, 67
                      >12, 12, 12, 12
                      >� � � � Tom Gutman
                      • Re: nth term formulas
                        Liv Bronze
                        Nice, like Babbage machine ...
                        Best, Liv
                      • nth term formulas
                        Silver
                        You're mixing up the threads. This sequence is the one from the other thread, which I covered in detail there. What tells you that the equation is a quadratic is not the value of the second differences, but the fact that the second differences are all equal. In the two series that you have the second differences are 12 in one and 4 in the other. But both have a quadratic form, because it is the second differences that are constant. If it were the third differences that were constant the form would be a cubic.
                        � � � � Tom Gutman
                        • nth term formulas
                          Copper
                          So if I have these terms:
                          -3 0 7 18 33 52
                          3 7 11 15 19 differences
                          4 4 4 4 differences
                          the second row of differences is constant (4) so my formula should be n+4 ??????..
                          I understand how to get the differences but when you say that by looking at a constant (4) the polynomial that generates the sequence will be a degree of ????....this is where I'm stuck.
                          HELP
                            • nth term formulas
                              superres Silver
                              > -3 0 7 18 33 52
                              >3 7 11 15 19
                              >differences
                              >4 4 4 4
                              >differences
                              >where I'm stuck.
                              >HELP
                              The second difference being a constant tells you that the equation is quadratic.
                              say the series is n2
                              The first differences are 3,5,7,9,11 and the second differences are 2,2,2,2.
                              say the series is 2n2
                              The first differences are 6,10,14,18,22 and the second differences are 4,4,4,4.
                              TTFN,
                              Eden
