9 Replies Latest reply: Feb 18, 2008 6:40 AM by HarikrishnanR RSS
    bom baloon index
    HendrikDenner Bronze
      Hi There Is there anyone who can tell me how to get the number inside the bom baloon to a letter I used the repeat region > #relation method from Andrew Deighton, this method changed my index in the bom from numbers to letters e.g 1 beacame A and so on, nut my bom baloons still show 1,2,3,4,5 ect. how can I get them to show A,B,C,D,E ect.. Thanks in advance Andrew Deighton's method for chaning bom index to alpha: i1=itos(rpt_index) letters = "ABCDEFGHIJKLMNOPQRSTUVWXYZ" i2=extract(letters,rpt_index,1) index=i2 I don't know why they declare i1 and don't use it.
        • RE: bom baloon index
          GavinFink Copper
          Hendrik, Now that the BOM has the alpha characters you have to set that parameter as the one that bom balloons display. Table->BOM Balloons->Set Param Select the repeat region then Select the column with the alpha character index parameter. Hope this helps! Regards, Gavin
              GavinFink Copper
              What happens if you have more than 26 items in your BOM?
                  when you have more than 26 numbers you will have to cater for them by starting fro AA - AZ, the descleration letters is what will be displayed in the index.
                      Doug Schaefer PTC Community Champion
                      I have an old (release 2000i I think) zip file with repeat region relations, a BOM table and a custom symbol that used the letters. I think it's set up to generate up to 4 levels deep of letters (A, AA, AAA, AAAA) I can email it to anyone, send me an email at 'd.schaefer at design-central dot com'. One thing to be aware of using this method: Back when I was investigating this about 7 years ago, this wouldn't work if you used another table order but the default. Pro|E, at least at that time, stored two values for rpt.idx, the default value and the value assigned using fix index. When evaluating relations, Pro|E uses the default value. I logged a call on this 'bug' and was told it was supposed to be that way. Maybe it's not anymore, I don't know, I gave up on Alpha BOMs after learning that.
