20 Replies Latest reply: Oct 29, 2010 8:41 AM by lvl107 RSS
    TRUE OR FALSE with this calculation ?
    lvl107 Gold
      Hello all,
      I really don't know that TRUE OR FALSE with this calculation ? Attach File below.
      Regard,
      Loi.
        • Re: TRUE OR FALSE with this calculation ?
          ViktorKorobov Silver
          Mathcad says it's true.
            MikeArmstrong Diamond
            Excel also says it's true.
            151.00000
            Mike
              Platinum
                Platinum
                The FPU (Floating Point Unit) is a separate part of your processor chip, dedicated to floating point (i.e., real number) arithmetics. It has been discovered that some parts of Windows 95/98 (or some drivers used by Windows) may affect the functioning of the FPU, reducing the accuracy of computations from about 19 to about 16 decimal digits.
                Most applications will never notice this, as they are usually limited to the 16-digit precision of the C/C++ double type. Kalkulator, however, takes the full advantage of the built-in FPU accuracy, and this advantage is cancelled when your system's FPU performance is degraded.
                Problems with the "old" Windows 95 System Agent
                Microsoft admitted (in a quite understated way) that the System Agent, included with the Win95 Plus, was affecting the FPU performance. The problem has been fixed in one of the Windows 95 Service Packs, and it should not be present at all in Windows 98. The culprit was identified as one of the Windows' components, sage.dll (version 4.40.310), and the fixed version number is 4.40.311. Turning the System Agent off is also a good workaround.
                Problems with other programs
                This is not the end of it. Exactly the same problem may sometimes arise without the System Agent (or sage.dll) running. I have so far identified two programs interfering with the FPU and causing exactly the same symptoms:
                ·     xwheel.exe by LCS/Telegraphics. This driver is included by many vendors with their pointing devices, touchpads in particular; probably more commonly seen on notebook computers. Removing xwheel.exe from the startup sequence fixes the FPU problem right away (in my Windows 98 tests I haven't lost any mouse functionality in the process).
                ·     vshield.exe, a memory-resident part of the McAfee antivirus utilities. Again programs of this kind are known to cause problems often. Disabling the Virus Shield fixes the problem.
                It is possible that these programs are not the real culprits here, but rather one of the Windows libraries they use; the bottom line remains the same.
                Kalkulator work-around
                Kalkulator runs a test for the FPU accuracy loss upon startup. If the problem is detected, the display precision setting will be limited to 16 (instead of 18) digits, and so will be the accuracy of some calculations. You will receive an appropriate warning when the FPU problem is detected the first time. If you change your system configuration (for example, by removing the offending program) and the problem goes away, the next time you run Kalkulator, it will detect this fact and give you a notice to this effect.
                More on the FPU problem
                You can find more details and updates on a Web page I have dedicated to it:
                where you will also find a small diagnostics program checking for this condition, together with the (very brief) source code.
                ____________________________
                Well explained by Richard & Eden
                The "Machine precision" as explained in Mathematica, is 16 for Pentium IV XP , and there is a test for it  it says my box is 16. There was another program causing failure of the floating point [Forge ?]. Ralston [if my recollection is correct] explained that the binary subtraction may eventually fail completely. That particular occurrence of numbers and operators will probably never happen in real engineering work, but nice to know it may cause some headache.
                jmG
                  lvl107 Gold
                  Thanks to all who replied.
                  Loi Le.
