14 Replies Latest reply: Sep 27, 2010 9:40 PM by jeanGiraud RSS
    Laplace Transform of integral
    Copper
      I got some homework to do and cant figure out how to solve an equation.
      I have an idea but I'm not sure if I can do it the way I want.
      As you can see in the document my problem is that the formula I use has f(t)dt in the integer but the equation I have to solve uses tau in in the integer but it wants me to take the integer from 0 to t.
      I don't feel like i explained the problem very well but it should be easier to understand if you read through the document.
      There might be other errors in the document but I have been wrestling with that part of the problem for what feels like hours now so I just finished it and threw it up here for you to have a look at.
      Anton
        • Re: Laplace Transform of integral
          Platinum
          It might be as simple as that. I didn't read the document, only your work sheet. The way the integral is shown is for continuous plotting . But in term of the numerical evaluation it is done between limits, between o and and the "end" in the Odesolve as well. That's my interpretation but wait more collabs agree on that interpretation.
          jmG
              Copper
              What I meant by document was Worksheet
              I dont think this is the answer I need, since i cant solve it numericaly. I would have no problem solving this equation if all the varibales had a value or if i had to find the laplace for the integer between 0 and t for y(t)*d*t
              But how would you find the laplace for the integer between 0 and t for y(tau)*d*tau. I cant find any examples thatt are simmilar, and I cant find any thing in my notes that help me here...
              I am beginning to think that it could be typing error on my teachers behalf.
              Anton
              AlvaroDíaz Silver
              Tay is a dummy variable, this is, some letter but can be any other. The primitive (this is, the integral transformation, not just a number, a function) of y(tau)dtau must to be applied following Barrow rule, this is, substracting the values from the end to the initial point. So, tay dissapear, and the integral is well writed.
              In the attached the solution. See the tables for the laplace transform properties to see how it applies to a derivative and to an integral. In mathcad 11 it can be automated to handle the entire process in only one function, but in mathcad 14 is ... better use copy, paste and editing.
              Regards. Alvaro.
                  Copper
                  Thank you
                  I looks about right. I got the same solution in another worksheet.
                  I'll find out if it is correct tomorrow
                  Anton
                    Platinum
                    Alvaro,
                    Your approach is not solvable toward an explicit solution. Your Laplace is undetermined naturally and incorrect in the sense of the next DE solver. The problem is not ill posed but "quizly posed" wrt the integrand. The integrand is not a function and will therefore have only a numerical running solution . The integrand and the differential operator is correct but these representation is only to isolate the solution for the running limit, which limit maybe simply linear or any nonlinear function itself. But for the case it is a member of a DE. the upper limit is the "end" of the DE . This type of homework quiz is typical of a "Mathcad classroom" It may have to be entered much differently in other CAS.
                    The other point is what is the point to transform something in the Laplace domain if no Laplace algebra is applied, good question indeed ! That problem reminds me the Melanie Turenne ITER DE. It was like abandoned though I had given the final Odesolve. About the ITER solution, it is obvious that there was a discontinuity in the solution and the final solution exhibits this discontinuity about the voltage surge in the cabling system, surge under opening the circuit. The discontinuity is in literature "courant de rupture" on what the breakers are designed wrt the energy it is desired to protect the grid.
                    Cheers Alvaro & collabs: Jean
                        AlvaroDíaz Silver
                        The proposed symbolic soltion verify the original equation. By theorems of unicity, given that a solution is proposed (even can be determined if it exists, is hard to handle, needs Lipschitz conditions or other hardest, and are not easy to prove) the solution is also unique. For this read the Check label in the file submited.
                        The correct interpretation for a definite integral as a function of the upper parameter is the given also. Notice that a "definite integral" is a real number, but a "primitive" is a function, or more preciselly, a familly of functions, if you take in consideration de usual "integration constant" C.
                        To avoid problems in the interpretations is why the integral parameter (tau in our case) is used, and not the upper limit (t). This is, a dummy variable (variable muda in spanish)
                        The proposed equation isn't an ODE. Is an integrodiferencial -in spanish- equation, and have a lot of common applications, not just for classroom.
                        In your gif, or the t in the upper limit of the integral isn't the same as the argument of laplace, or is a bug in mcad11. The property to apply is:
                        laplace(int(y(tau),tau=0..t),t,s) = laplace(y(t),t,s)/s
                        Check laplace tables for it.
                        In the attached the symbolic and the numerical soltuions, and the plots, showing that are basically the same.
                      Platinum
                      Collab,
                      I have reviewed your "final". It is wrong !
                      1. The DE is a DE and not an "Integral Equation" [Fredholm, Voltera ...]
                      On that point you are correct.
                      2. Where you have "solve", that is not correct. There is nothing to solve but collect for Y(s), then apply ordinary algebra on that Laplace representation, isolate for Y(s) and the solution in "InverseLaplace", then plug m, n, Y0, end.
                      3. This type of DE can't go in the generalized Odesolve, it is not linear in term of the integral operator but it is in the Laplace domain. The 1rst order DE has the Laplace solver shown , which solver simply needs to include the Laplace operator n/s. Don't get confused with the representation of the integral operator, it simply indicates that this term ranges on the same ' t' as in the forcing term. There is no other way to indicate it than the way it is shown, and it is most essential otherwise it would be confusing as it could be interpreted as the integral could stop in the range you would expect a solution.
                      So, here is the final solution. You can copy the RHS term of the symbolic "InverseLaplace" and transport it to low level software and you will get a general solution depending upon : m, n, Y0, end. More than often a DE expression is most confusing by lack of formal symbolism and the teacher inadapted to CAS . Mathematica 4.0 is very poor in examples of symbolic DE solution.
                      jmG
                        Platinum
                        Anton, Alvaro,
                        Nothing has changed, the solver is totally correct in two lines of code. The route to the solver is a long story in the former Akiva collab. It comes out from Mathcad Maple 11.2a but I have not conserved the construct once proved and tested. In case Mathcad 14/15/Prime does not like the solver, here is also the image. The notation given by the "Professor" in cause and in quiz is incorrect. It is correct in the sense that the construct would arrive at the same result via the step function [f] integrated over Dirac D(t). The result is the same to the solver, but like giving the alphabet to explain a word or if you prefer: skinning the cat with a robot instead of by hands. If you want an export, evaluate the compacted red instruction, copy or "transport" the RHS of the symbolic evaluation. That will make the given DE work in low software like Excel and subjected to the project conditions.
                        There is lot less theory in books for Engineers than in the web for distraction.
                        Projects need what make them work and produce.
                        Cheers, Jean
                        • Re: Laplace Transform of integral [Laplace solvers]
                          Platinum
                          A nice project that was missing for the tool box.
                          Done Mathcad 11.2a , no red except intentional
                          for the symbolic compactor. Hope it works in
                          versions 14/15/Prime.
                          Thanks Alvaro for your input.
                          Jean
