First I want to excuse me for my bad english, since yesterday CoCreate 3.0 PE doesn´t work. When I open the program it says : create_vp/signal/sigsegv
Probaly anyone knows this error and could help me !? Thank you
Christopher S
i have the same problem. have you solved it?
seems to be an issue when the system initializes the 3D Viewport.
Please check the following
http://communities.ptc.com/community/creo-elements-direct/pe-english?view=all#
In the Announcement Tab - Number 5 there is a list of tested cards. Is the one listed you are using?
Creo Elements/Direct Modeling PE has been successfully tested on the most common Nvidia and ATI mobile-, workstation- and consumer-graphic boards together with Windows Vista (see table below).PTC does not guarantee full operability on Intel Media Accelerators or other on-board chipsets.
And a second check is
