2 Replies Latest reply: Jun 15, 2011 12:21 AM by JorgSerdons RSS
    Pro/Engineer + Structure and Thermal Solutions 2.0
    JorgSerdons Copper
      Our Old PC running proengineer 2.0 Died
      The Licensing ran Standalone on that Pc and Proengineer worked fine with Structure
      We have managed to Install this software on a different Pc with network licensing on an indepent server
      ProEngineer itself works fine using the licensing server but Structure refuses to load and trows up a Licensing Error
      Our Server Runs Lmtools that comes with Version 5.0 of Proengineer, the License was all done Via de PTC Licensing system
      We get the Error "Unknown Licensing Error 26" in Structure
      Does Structure need extra configuration to work with the License Server? or maybe there is something wrong with the license file
      I know 2.0 is pretty old but thats what the licensing is for
      Any help is greatly apreciated
        • Re: Pro/Engineer + Structure and Thermal Solutions 2.0
          BrentDrysdale Silver
          Hi Jorg,
          I can't say for that particular error but do know that you need to include the server information for the mechanica when you run ptcsetup.bat
          I have attached a PDF that shows what I see in our setup. Obviously you will have different names/locations.
          Not sure if this helps at all. I have not tried to run Mechanica from the WF2 period though I it is possible for me to run WF2 ProE.
          Regards, Brent
              JorgSerdons Copper
              Hi Brent,
              New Information as come to light
              We are able to run Simulation within proengineer
              I've noticed in your PDF there are 2 License Instances running
              we only have one Licence instance running
              We think when the Server License got created the Structure (indepedant) bit got left out
              Current Licensing on PT Licensing portal
              Filter | Sort
              Filter | Sort
              Filter | Sort
              Creo Parametric (formerly Foundation XE)
              Creo Parametric & Pro/ENGINEER
              FLOATING LICENSE
              Wildfire 2.0
              Perpetual / Commercial-Government
              1 of 1
              5A115xxxx
              Mechanism Design
              LOCKED MODULE
              Wildfire 2.0
              1 of 1
              5A115xxxx
              Creo Simulation (formerly Pro/ENGINEER)
              Creo Simulate & Mechanica
              FLOATING LICENSE
              Wildfire 2.0
              1 of 1
              5A115xxx
              Message was edited by: Jorg Serdons
