7 Replies Latest reply: Sep 25, 2012 4:35 PM by Andy Delk RSS
    New install of WC 10:  Worked fine the first time, now nothing.
    Andy Delk Bronze
      ***It has now been confirmed this is an issue with WC 10.0 and is being looked into. It will go to R&D if a quick solution isn't found***
      Hi guys,
      Setup on a dev box. After the initial install everything worked fine. After the reboot all I get is the PTC spinning wheel after I login to the website. Any ideas?
      • I have DS running, Apache running, and Windchill running.
      • Server 2008 R2 8GB RAM
      2011-06-30 09:34:41,937 INFO [main] wt.method.server.startup - Starting MethodServer
      2011-06-30 09:34:41,941 INFO [main] wt.method.server.startup - JVM id: 4944
      2011-06-30 09:34:41,941 INFO [main] wt.method.server.startup - JVM: Sun Microsystems Inc., Java HotSpot(TM) 64-Bit Server VM, 1.6.0_24 (19.1-b02), 64-bit
      2011-06-30 09:34:41,941 INFO [main] wt.method.server.startup - OS: Windows Server 2008, amd64, 6.0
      2011-06-30 09:34:41,943 INFO [main] wt.method.server.startup - Host: CORCEDEV02 (corcedev02.corp.jabil.org)
      2011-06-30 09:34:41,944 INFO [main] wt.method.server.startup - Class path =
      C:\ptc\Windchill_10.0\Windchill\codebase
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\archiveClientWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\archiveServerWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\archiveWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\CounterPartWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\dpimplWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\dpinfraWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\Gantt.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\ie3rdpartylibs.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\ieWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\install.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\jmxcoreWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\jviews-chart-all.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\jviews-framework-all.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\jviews-gantt-all.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\mylyn-integration.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\pdmlWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\prowtWeb.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\wc3rdpartylibs.jar
      C:\ptc\Windchill_10.0\Windchill\codebase\WEB-INF\lib\wncWeb.jar
      C:\ptc\Windchill_10.0\Windchill\lib\pdml.jar
      C:\ptc\Windchill_10.0\Windchill\lib\servlet.jar
      C:\ptc\Windchill_10.0\Windchill\lib\wnc.jar
      C:\ptc\Windchill_10.0\Java\lib\tools.jar
      C:\ptc\Windchill_10.0\Windchill\tomcat\bin\bootstrap.jar
      C:\ptc\Windchill_10.0\Windchill\srclib\wnc\WtAsmAgent.jar
      2011-06-30 09:34:41,945 INFO [main] wt.method.server.startup - Setting WTContext time zone to America/New_York; offset: -4.0
      2011-06-30 09:34:41,970 INFO [main] wt.method.server.startup - Setting default time zone to GMT; offset: 0.0
      2011-06-30 09:34:50,837 INFO [main] wt.pom.properties - wt.pom.maxDbConnections= 15
      2011-06-30 09:34:50,837 INFO [main] wt.pom.properties - wt.pom.minDbConnections= 5
      2011-06-30 09:34:50,837 INFO [main] wt.pom.properties - wt.pom.dbConnectionsHardLimits= 25
      2011-06-30 09:34:50,837 INFO [main] wt.pom.properties - wt.pom.dbConnectionsSoftLimitWaitTime= 0
      2011-06-30 09:34:50,838 INFO [main] wt.pom.properties - wt.pom.dbConnectionsWaitTime= 0
      2011-06-30 09:34:50,838 INFO [main] wt.pom.properties - wt.pom.connectionCloserThreshold= 0
      2011-06-30 09:34:50,838 INFO [main] wt.pom.properties - wt.pom.connectionCloserIdleTimeout= 0
      2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.connectionMonitorSleepInterval= 10
      2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.lostConnectionCodes=
      2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.recoverableConnectionCodes= 28,1012,17002,17008
      2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.freeConnectionImmediate= false
      2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.maxIdleStatementCaches= 0
      2011-06-30 09:34:50,839 INFO [main] wt.pom.properties - wt.pom.jdbc.driver= com.microsoft.sqlserver.jdbc.SQLServerDriver
      2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.url= jdbc:sqlserver:
      2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.host= corcedev02.corp.jabil.org
      2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.port= 1433
      2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.service=
      2011-06-30 09:34:50,840 INFO [main] wt.pom.properties - wt.pom.jdbc.database= wcsql1
      2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.dbUser= wcsql1
      2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.dbSchemaUser= wcsql1
      2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.dbConnectionPropertiesNameList=
      2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.dbConnectionPropertiesValueList=
      2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.userDefinedFunctionsFileName= C:\ptc\Windchill_10.0\Windchill\db\userDefinedFunctions.xml
      2011-06-30 09:34:50,841 INFO [main] wt.pom.properties - wt.pom.rowPrefetchCount= 20
      2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.statementCacheSize= 50
      2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.cachedStatementReuseLimit= 50
      2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.feedbackInterval= 500
      2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.interruptInterval= 50
      2011-06-30 09:34:50,842 INFO [main] wt.pom.properties - wt.pom.cachedStatementRSLimit= -1
      2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.navigateDepthThreshold= 4
      2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.navigateDepthUnionLimit= 10
      2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.queryDepthThreshold= 3
      2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.queryDepthInClauseSizeLimit= 50
      2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.lobChunkSize= 32000
      2011-06-30 09:34:50,843 INFO [main] wt.pom.properties - wt.pom.log.JDBCStatements= false
      2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.log.fileJDBC= null
      2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.log.filterJDBC= null
      2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.chunk.defaultSize= 50
      2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.objectReferenceQuerySize= 254
      2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.objectReferenceQueryChunkSize= 500
      2011-06-30 09:34:50,844 INFO [main] wt.pom.properties - wt.pom.objectReferenceArrayTableEnabled= false
      2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.inflateHint= RULE
      2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.inflateSingleTableMode= true
      2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.useBind= true
      2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.inClauseFixedSize= 5
      2011-06-30 09:34:50,845 INFO [main] wt.pom.properties - wt.pom.inClauseSizeLimit= 1000
      2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseBindLimit= 51
      2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseUseBindOptimization= true
      2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationThreshold=50
      2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationTempTableUsePrimaryKey=true
      2011-06-30 09:34:50,846 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationCardinality=-1
      2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.cardinalityValueFixedSize= 100
      2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.tempTableNumberPerThreshold= 5
      2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.tempTableArraySizeNumberOfThreshold=3
      2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.tempTableArraySizeThresholdValues=200,1000, 2000
      2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.startupQueryLimit= -1
      2011-06-30 09:34:50,847 INFO [main] wt.pom.properties - wt.pom.queryLimit= -1
      2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.queueInvokeTime= 600
      2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.sessionCleanupTime= 1800
      2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.threshold= -1
      2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.insertChunkSize= 250
      2011-06-30 09:34:50,848 INFO [main] wt.pom.properties - wt.pom.paging.fetchLimit= 15
      2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.paging.fetchSleepInterval= 1000
      2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.paging.closeSleepInterval= 600
      2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.paging.snapshotQueryLimit= 100000
      2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.paging.pagingSessionLimit= 5
      2011-06-30 09:34:50,849 INFO [main] wt.pom.properties - wt.pom.statementCache.summaryInterval= 2000
      2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.enableNLSSort= false
      2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.constantArrayTableLimit= 4000
      2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.traceTiming.enable= true
      2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.blobRead.handle620LV= false
      2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.blobRead.handleOldLV= false
      2011-06-30 09:34:50,850 INFO [main] wt.pom.properties - wt.pom.blobRewrite.enabled= false
      2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.selectForUpdateEnabled= false
      2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.refreshCache.enabled= true
      2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.refreshCache.summeryInterval= 0
      2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.refreshCache.size= 300
      2011-06-30 09:34:50,851 INFO [main] wt.pom.properties - wt.pom.enableSQL99OuterjoinSyntax= true
      2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.enableInListOptimizationWarning= false
      2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.chunkThreshold=-1
      2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.roleChunkSize=-1
      2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.objectChunkSize=-1
      2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.refIntegrity.removeOids.objectChunkSize=-1
      2011-06-30 09:34:50,852 INFO [main] wt.pom.properties - wt.pom.batch.spec.tableExpressionThreshold=-1
      2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.spec.useTableType= true
      2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.spec.useColumnList= true
      2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.classChunkSize= 2000
      2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.chunkSize= 5000
      2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.retry.enable= false
      2011-06-30 09:34:50,853 INFO [main] wt.pom.properties - wt.pom.batch.closePreparedStatement.threshold=-1
      2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.batch.insert.chunkSize= -1
      2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.batch.update.chunkSize= 5000
      2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.maxQueryRetryCount= 5
      2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.oracle.blobInlineWriteThreshold= -1
      2011-06-30 09:34:50,854 INFO [main] wt.pom.properties - wt.pom.oracle.disableAlwaysSemiJoin= true
      2011-06-30 09:34:50,855 INFO [main] wt.pom.properties - wt.pom.oracle.jdbcConnectionMemoryLimit= 48
      2011-06-30 09:34:50,855 INFO [main] wt.pom.properties - wt.pom.oracle.nlssort.truncateLength= 600
      2011-06-30 09:34:50,855 INFO [main] wt.pom.properties - wt.pom.emptyTableQueryClassChunkSize = 400
      2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.size = 7
      2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.queueSize = -1
      2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.implicitEnabled=false
      2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - Windchill DataStore: SQLServer
      2011-06-30 09:34:50,857 INFO [main] wt.pom.properties - JDBC Driver Version: major=3 minor=0
      2011-06-30 09:34:51,894 INFO [main] wt.method.server.startup - MethodServer created - port 5003
      2011-06-30 09:34:51,894 INFO [main] wt.method.server.startup - Starting services - class = wt.services.StandardServicesHandler
      2011-06-30 09:35:25,239 INFO [main] wt.pom.properties - wt.pom.delete.triggerClassNames=
      2011-06-30 09:36:20,379 INFO [main] wt.pom.properties - Connection: datastore=Microsoft SQL Server(10.50.1600) jdbcVersion=4.0 driver=Microsoft SQL Server JDBC Driver 3.0(3.0.1301.101) driverVersion=3.0
      2011-06-30 09:36:24,110 ERROR [main] wt.audit.StandardAuditService - Project Audit Service: failed to set Administrator (ok if installation)
      2011-06-30 09:36:28,790 ERROR [main] wt.access.agreement.StandardAgreementService - Agreement Service: failed to set Administrator (ok if installation)
      2011-06-30 09:36:29,494 ERROR [main] wt.lifecycle - LifeCycle Service: failed to set Administrator (ok if installation)
      2011-06-30 09:36:33,418 ERROR [main] wt.wrmf - wrmf.delivery.ShippingService: failed to set Administrator (ok if installation)
      2011-06-30 09:36:33,617 ERROR [main] wt.workflow.forum.StandardForumService - StandardForumService : failed to set Administrator (ok if installation)
      2011-06-30 09:36:33,681 ERROR [main] com.ptc.windchill.counterpart.StandardCounterPartService - Failed to set Administrator (ok if installation)
      2011-06-30 09:36:35,088 INFO [com.ptc.core.logic.repository.server.impl.ChangeLocator$LoadLogicRepositoryTask] com.ptc.core.logic.repository.server.impl.ChangeLocator - Starting LoadLogicRepositoryTask.run()
      2011-06-30 09:36:35,186 INFO [NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Started initializeXML()
      2011-06-30 09:36:35,474 INFO [com.ptc.core.logic.repository.server.impl.ChangeLocator$LoadLogicRepositoryTask] com.ptc.core.logic.repository.server.impl.ChangeLocator - Finished LoadLogicRepositoryTask.run()
      2011-06-30 09:36:37,169 ERROR [main] com.ptc.core.lwc.server.cache.db.TypeDefinitionDBService - Type Definition Service: failed to set Administrator (ok if installation)
      2011-06-30 09:36:37,735 ERROR [main] wt.dataops.objectcol.StandardCollectionService - dataops.objectcol.CollectionService: failed to set Administrator (ok if installation)
      2011-06-30 09:37:05,130 INFO [NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Finished initializeXML()
      2011-06-30 09:37:13,089 ERROR [main] wt.vc.StandardVersionControlService - StandardVersionControlService: failed to set Administrator (ok if installation)
      2011-06-30 09:37:14,313 INFO [main] wt.method.server.startup.services - All managers started.
      2011-06-30 09:37:14,314 INFO [main] wt.method.server.startup - StandardManagerService started
      2011-06-30 09:37:14,314 INFO [main] wt.method.server.startup - Services started.
      2011-06-30 09:37:14,473 INFO [main] wt.method.server.startup - MethodServer registered with ServerManager
      2011-06-30 09:37:14,474 INFO [main] wt.method.server.startup - Creating com.ptc.tomcat.embedded.Bootstrap
      2011-06-30 09:37:14,501 INFO [main] wt.method.server.startup - Creating wt.method.WTAdapter
      2011-06-30 09:37:14,545 INFO [main] wt.method.server.startup - Creating com.ptc.core.adapter.server.impl.SimpleTaskDispatcher
      2011-06-30 09:37:14,687 INFO [main] wt.method.server.startup - Creating wt.method.ClusterMonitor
      2011-06-30 09:37:14,709 INFO [main] wt.method.server.startup - Creating wt.method.jmx.Startup
      2011-06-30 09:37:20,715 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.methodServer.info - JVMName=4944@CORCEDEV02,
      StartTime=1309440878535,
      MaxHeapBytes=2433875968,
      ServiceName=MethodServer,
      JVMArguments=[-XX:+UseCompressedOops,
      -javaagent:C:\ptc\Windchill_10.0\Windchill\srclib\wnc\WtAsmAgent.jar,
      -Xverify:none,
      -Xrs,
      -Djava.endorsed.dirs=C:\ptc\Windchill_10.0\Windchill\lib\endorsed,
      -Djava.awt.headless=true,
      -Dwt.manager.serviceName=MethodServer,
      -Dwt.logs.dir=C:\ptc\Windchill_10.0\Windchill\logs,
      -Dcom.sun.management.jmxremote,
      -Djmx.remote.protocol.provider.pkgs=wt.jmx.remote.protocol,
      -Dlog4j.configuration=WEB-INF/log4jMethodServer.properties,
      -Dwt.tomcat.embeddedMode.enable=true,
      -Xms2422m,
      -Xmx2422m,
      -XX:PermSize=184m,
      -XX:MaxPermSize=400m,
      -Dsun.rmi.dgc.client.gcInterval=3600000,
      -Dsun.rmi.dgc.server.gcInterval=3600000,
      -Xloggc:C:\ptc\Windchill_10.0\Windchill\logs\MethodServer-110630093437415-2-GC.log,
      -XX:+PrintGCDetails,
      -XX:+PrintGCDateStamps],
      AvailableProcessors=2
      2011-06-30 09:37:21,589 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=140087536, NonHeapMemoryUsage=106958464, Uptime=163054, ProcessCpuTime=47703125000, JITCTime=24291, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[672,534], GCCount=[2,4], Classes=11371, Threads=36, TotalStartedThreadCount=43, PermGenPercentCollUsage=24.219070434570312, PermGenPercentUsage=24.219070434570312
      2011-06-30 09:37:21,613 ERROR [main] wt.method.jmx.LogTableCleaner - Failed to set Administrator (OK if installation)
      2011-06-30 09:37:21,613 INFO [main] wt.method.server.startup - Creating wt.phonehome.queue.PhoneHomeQueueScheduler
      2011-06-30 09:37:21,929 INFO [main] wt.method.server.startup - Creating com.ptc.tomcat.embedded.Bootstrap$WaitUntilStarted
      2011-06-30 09:37:40,216 INFO [Tomcat main] org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'MVCDispatcher': initialization started
      2011-06-30 09:38:00,828 INFO [Tomcat main] org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'MVCDispatcher': initialization completed in 20610 ms
      2011-06-30 09:38:00,980 INFO [Tomcat main] com.ptc.tomcat.embedded.Bootstrap - Embedded Tomcat ready; catalina.base=C:\ptc\Windchill_10.0\Windchill\tomcat\instances\instance-8010
      2011-06-30 09:38:00,984 INFO [main] wt.method.server.startup - MethodServer ready (in 202.449 secs).
      2011-06-30 09:41:33,536 ERROR [TP-Processor7] org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill] - Session event listener threw exception
      wt.util.WTRuntimeException: wt.util.WTException: java.lang.reflect.InvocationTargetException
      Nested exception is: java.lang.reflect.InvocationTargetException; nested exception is:
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at com.ptc.core.appsec.FoundationHolder.getPrincipal(FoundationHolder.java:263)
      at com.ptc.core.appsec.FoundationHolder.getPrincipalName(FoundationHolder.java:188)
      at com.ptc.core.appsec.CSRFNonce.createMessage(CSRFNonce.java:411)
      at com.ptc.core.appsec.CSRFNonce.initializeMac(CSRFNonce.java:306)
      at com.ptc.core.appsec.CSRFNonce.initialize(CSRFNonce.java:153)
      at com.ptc.core.appsec.CSRFNonce.newCSRFNonce(CSRFNonce.java:122)
      at com.ptc.core.appsec.CSRFProtector.addNonce(CSRFProtector.java:285)
      at com.ptc.core.appsec.CSRFSessionListener.sessionCreated(CSRFSessionListener.java:37)
      at org.apache.catalina.session.StandardSession.tellNew(StandardSession.java:381)
      at org.apache.catalina.session.StandardSession.setId(StandardSession.java:353)
      at org.apache.catalina.session.ManagerBase.createSession(ManagerBase.java:881)
      at org.apache.catalina.session.StandardManager.createSession(StandardManager.java:291)
      at org.apache.catalina.connector.Request.doGetSession(Request.java:2411)
      at org.apache.catalina.connector.Request.getSession(Request.java:2120)
      at org.apache.catalina.connector.RequestFacade.getSession(RequestFacade.java:833)
      at wt.servlet.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:130)
      at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:216)
      at org.apache.catalina.core.ApplicationHttpRequest.getSession(ApplicationHttpRequest.java:547)
      at org.apache.catalina.core.ApplicationHttpRequest.getSession(ApplicationHttpRequest.java:493)
      at org.apache.jasper.runtime.PageContextImpl._initialize(PageContextImpl.java:146)
      at org.apache.jasper.runtime.PageContextImpl.initialize(PageContextImpl.java:124)
      at org.apache.jasper.runtime.JspFactoryImpl.internalGetPageContext(JspFactoryImpl.java:107)
      at org.apache.jasper.runtime.JspFactoryImpl.getPageContext(JspFactoryImpl.java:63)
      at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:84)
      at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
      at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:386)
      at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313)
      at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260)
      at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
      at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
      at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646)
      at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436)
      at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374)
      at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302)
      at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:238)
      at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:250)
      at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1063)
      at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:801)
      at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
      at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
      at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
      at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:61)
      at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
      at wt.httpgw.filter.TrustedAuthFilter.doFilter(TrustedAuthFilter.java:130)
      at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:231)
      at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:325)
      at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1591)
      at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:56)
      at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
      at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
      at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
      at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
      at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
      at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
      at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
      at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
      at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:811)
      at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:740)
      at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:933)
      at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
      at java.lang.Thread.run(Thread.java:662)
      Caused by: (wt.session.sessionResource/2) wt.org.UserNotFoundException: User not found: unknown web name: "wcadmin".
      at wt.session.StandardSessionManager.getAuthenticatedUser(StandardSessionManager.java:426)
      at wt.session.StandardSessionManager.getPrincipal(StandardSessionManager.java:178)
      at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:249)
      at $Proxy16.getPrincipal(Unknown Source)
      at wt.session.SessionHelper.getPrincipal(SessionHelper.java:157)
      ... 80 more
      2011-06-30 09:41:33,786 ERROR [TP-Processor7] com.ptc.windchill.enterprise.navigation - Can't find WTUser on Session
      at com.ptc.windchill.enterprise.navigation.renderers.HeaderUtil.getUserInfo(HeaderUtil.java:121)
      at com.ptc.windchill.enterprise.navigation.renderers.HeaderUtil.getWelcomeMessage(HeaderUtil.java:104)
      at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:159)
      2011-06-30 09:41:34,001 ERROR [TP-Processor7] com.ptc.jca.navigation - problem getting the main navigation action model
      at wt.session.StandardSessionManager.getPrincipalReference(StandardSessionManager.java:200)
      at $Proxy16.getPrincipalReference(Unknown Source)
      at com.ptc.netmarkets.util.misc.StandardNmActionService.createValidationCriteria(StandardNmActionService.java:3042)
      at com.ptc.netmarkets.util.misc.StandardNmActionService.getValidatedActionModel(StandardNmActionService.java:2798)
      at com.ptc.netmarkets.util.misc.StandardNmActionService.getActionModel(StandardNmActionService.java:561)
      at $Proxy24.getActionModel(Unknown Source)
      at com.ptc.windchill.enterprise.navigation.delegates.DefaultNavigationListDelegate.getActionModel(DefaultNavigationListDelegate.java:209)
      at com.ptc.windchill.enterprise.navigation.delegates.DefaultNavigationListDelegate.getJSONForShell(DefaultNavigationListDelegate.java:440)
      at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:162)
      2011-06-30 09:41:34,096 ERROR [TP-Processor7] com.ptc.windchill.uwgm.common.container.ContainerUtilities - ContainerUtilities.getOrgContainerOfSessionUser :: (wt.session.sessionResource/2) wt.org.UserNotFoundException: User not found: unknown web name: "wcadmin".
      2011-06-30 09:41:34,199 WARN [TP-Processor7] com.ptc.windchill.uwgm.common.prefs.UwgmPreferences - UwgmPreferencesImpl.<init> :: Cannot obtain a principal from Session
      at com.ptc.windchill.uwgm.common.prefs.UwgmPreferencesImpl.<init>(UwgmPreferencesImpl.java:66)
      at com.ptc.windchill.uwgm.common.prefs.UwgmPrefFactory.getPreferences(UwgmPrefFactory.java:34)
      at com.ptc.core.htmlcomp.util.preference.PreferenceContext.createPreferenceContext(PreferenceContext.java:143)
      at com.ptc.core.htmlcomp.util.preference.PreferenceContext.newPreferenceContext(PreferenceContext.java:89)
      at com.ptc.core.htmlcomp.util.preference.PreferenceContext.newPreferenceContext(PreferenceContext.java:114)
      at com.ptc.core.htmlcomp.util.DateFormatUtilities.getLocalTimeZone(DateFormatUtilities.java:297)
      at com.ptc.core.htmlcomp.util.DateFormatUtilities.createTimeZoneDisplayNamesJSON(DateFormatUtilities.java:435)
      at com.ptc.core.htmlcomp.util.DateFormatUtilities.printDateFormatJS(DateFormatUtilities.java:127)
      at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:214)
      2011-06-30 09:41:36,367 ERROR [TP-Processor7] com.ptc.core.components.jsp.JspUtils - wt.util.WTRuntimeException: wt.util.WTException: java.lang.reflect.InvocationTargetException
      at com.ptc.core.appsec.CSRFProtector.getNonce(CSRFProtector.java:136)
      at com.ptc.core.appsec.CSRFProtector.getNonce(CSRFProtector.java:115)
      at com.ptc.core.appsec.CSRFProtector.getNonce(CSRFProtector.java:93)
      at com.ptc.core.components.tags.components.RenderMainFormTag.printForm(RenderMainFormTag.java:130)
      at com.ptc.core.components.tags.components.RenderMainFormTag.doTag(RenderMainFormTag.java:74)
      at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspx_meth_jca_005frenderMainForm_005f0(clearDynamicAttributes_jsp.java:1441)
      at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspx_meth_c_005fif_005f9(clearDynamicAttributes_jsp.java:1413)
      at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspx_meth_c_005fif_005f8(clearDynamicAttributes_jsp.java:1350)
      at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspService(clearDynamicAttributes_jsp.java:298)
      at com.ptc.core.components.filter.JCAFilter.doFilter(JCAFilter.java:96)
      ... 60 more
      2011-06-30 09:41:36,376 ERROR [TP-Processor7] wt.method.MethodContextMonitor.contexts.servletRequest - 2011-06-30 13:41:35.779 +0000, 1br44s1;gpjrari4;4944;pot4xk;82, -, -, 1br44s1;gpjrari4;4944;pot4xk;81, wcadmin, 172.27.8.49, -, -, , 0, 0, 0.001332012, 0.21875, 0.595372596
      javax.servlet.ServletException: javax.servlet.jsp.JspException: Unable to print mainform
      at org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:861)
      at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:794)
      at org.apache.jsp.netmarkets.jsp.util.clearDynamicAttributes_jsp._jspService(clearDynamicAttributes_jsp.java:759)
      Caused by: wt.util.WTRuntimeException: wt.util.WTException: java.lang.reflect.InvocationTargetException
      at com.ptc.core.appsec.FoundationHolder.getPrincipalName(FoundationHolder.java:191)
      ... 40 more
      Caused by: wt.util.WTException: java.lang.reflect.InvocationTargetException
      at com.ptc.core.appsec.FoundationHolder.getPrincipal(FoundationHolder.java:265)
      ... 54 more
      Caused by: java.lang.reflect.InvocationTargetException
      ... 55 more
      ... 60 more
      2011-06-30 09:41:36,383 ERROR [TP-Processor7] wt.servlet.ServletRequestMonitor.request wcadmin - 2011-06-30 13:41:35.778 +0000, 1br44s1;gpjrari4;4944;pot4xk;81, wcadmin, 172.27.8.49, /Windchill/netmarkets/jsp/util/clearDynamicAttributes.jsp, dynamicFlush=true, POST, 302, 0.234375, 0.602721575
      ... 60 more
      2011-06-30 09:41:36,387 ERROR [TP-Processor7] org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill].[jsp] - Servlet.service() for servlet jsp threw exception
      2011-06-30 09:47:18,131 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.001539861, CompletedContexts=22, ErrorCount=1, RedirectCount=0, ContextSecondsAverage=2.4308329945000002, ContextSecondsMax=46.233862404, ContextCpuSecondsAverage=0.8053977272727273, ContextUserSecondsAverage=0.6065340909090909, ContextJDBCConnWaitSecondsAverage=9.724445454545455E-5, ActiveContextsAverage=0.6899436152912244, ActiveContextsMax=4, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=1.0454545454545454, PercentageOfContextTimeInJDBCCalls=1.8956242483986976, PercentageOfContextTimeInJDBCConnWait=0.004000458063778126, PercentageOfContextTimeInJNDICalls=0.8032379808820455
      2011-06-30 09:47:18,233 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=600.053, CompletedContexts=20, ErrorCount=0, ContextSecondsAverage=0.0313805525, ContextSecondsMax=0.249271905, ContextCpuSecondsAverage=0.00859375, ContextUserSecondsAverage=0.0046875, ActiveContextsAverage=0.0010467836041149698, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
      2011-06-30 09:47:18,292 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=659.502, TotalContexts=52, ErrorCount=0, ContextsPerSecond=0.07884737271456342, AverageContextSeconds=0.015888880076923077, LongestContextSeconds=0.233806811, AverageActiveContexts=0.0012524956967530046, MaxActiveContexts=1
      2011-06-30 09:47:18,292 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=733.311, TotalContexts=30, ErrorCount=0, ContextsPerSecond=0.040910336814802994, AverageContextSeconds=0.024433021533333335, LongestContextSeconds=0.183655744, AverageActiveContexts=9.984267261775699E-4, MaxActiveContexts=1
      2011-06-30 09:47:22,339 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=154370744, NonHeapMemoryUsage=141988648, Uptime=763803, ProcessCpuTime=86109375000, JITCTime=42049, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[1314,761], GCCount=[3,7], Classes=15447, Threads=48, TotalStartedThreadCount=131, PermGenPercentCollUsage=31.911172866821293, PermGenPercentUsage=31.911172866821293
      2011-06-30 09:47:36,066 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.001651048, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 09:47:36,720 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.001885715, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 09:47:39,588 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=0.610259800292909, ActiveSessionsMax=1, ActiveSessionsStart=0, ActiveSessionsEnd=1, ElapsedSeconds=600.001103772, SessionsCreated=1, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 09:47:40,252 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.001945219, CompletedRequests=4, ErrorCount=0, RequestSecondsAverage=0.8849283215, RequestSecondsMax=2.518869018, RequestCpuSecondsAverage=0.25390625, RequestUserSecondsAverage=0.17578125, ActiveRequestsAverage=0.005943699370338424, ActiveRequestsMax=1, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 09:57:18,157 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.002929143, CompletedContexts=9, ErrorCount=0, RedirectCount=0, ContextSecondsAverage=0.01028737188888889, ContextSecondsMax=0.016413818, ContextCpuSecondsAverage=0.008680555555555556, ContextUserSecondsAverage=0.006944444444444444, ContextJDBCConnWaitSecondsAverage=7.667E-6, ActiveContextsAverage=1.0001543098250074, ActiveContextsMax=2, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=0.0, PercentageOfContextTimeInJDBCCalls=0.0, PercentageOfContextTimeInJDBCConnWait=0.07452826711048445, PercentageOfContextTimeInJNDICalls=0.0
      2011-06-30 09:57:18,257 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=600.024, CompletedContexts=0, ErrorCount=0, ContextSecondsAverage=NaN, ContextSecondsMax=0.0, ContextCpuSecondsAverage=NaN, ContextUserSecondsAverage=NaN, ActiveContextsAverage=0.0, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
      2011-06-30 09:57:18,318 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=600.026, TotalContexts=0, ErrorCount=0, ContextsPerSecond=0.0, AverageContextSeconds=0.0, LongestContextSeconds=0.0, AverageActiveContexts=0.0, MaxActiveContexts=0
      2011-06-30 09:57:18,318 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=600.026, TotalContexts=0, ErrorCount=0, ContextsPerSecond=0.0, AverageContextSeconds=0.0, LongestContextSeconds=0.0, AverageActiveContexts=0.0, MaxActiveContexts=0
      2011-06-30 09:57:23,290 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=128092576, NonHeapMemoryUsage=141580296, Uptime=1364754, ProcessCpuTime=87796875000, JITCTime=42157, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[2233,766], GCCount=[4,8], Classes=15450, Threads=48, TotalStartedThreadCount=201, PermGenPercentCollUsage=31.80964851379395, PermGenPercentUsage=31.80964851379395
      2011-06-30 09:57:36,091 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.001927619, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 09:57:36,745 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.001923708, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 09:57:39,613 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=1.0, ActiveSessionsMax=1, ActiveSessionsStart=1, ActiveSessionsEnd=1, ElapsedSeconds=600.001905829, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 09:57:40,276 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.000997333, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:07:18,182 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.001928178, CompletedContexts=8, ErrorCount=0, RedirectCount=0, ContextSecondsAverage=0.010269461375, ContextSecondsMax=0.015265069, ContextCpuSecondsAverage=0.01171875, ContextUserSecondsAverage=0.005859375, ContextJDBCConnWaitSecondsAverage=1.236175E-5, ActiveContextsAverage=1.0001369257116381, ActiveContextsMax=2, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=0.0, PercentageOfContextTimeInJDBCCalls=0.0, PercentageOfContextTimeInJDBCConnWait=0.12037388864515788, PercentageOfContextTimeInJNDICalls=0.0
      2011-06-30 10:07:18,282 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=600.025, CompletedContexts=0, ErrorCount=0, ContextSecondsAverage=NaN, ContextSecondsMax=0.0, ContextCpuSecondsAverage=NaN, ContextUserSecondsAverage=NaN, ActiveContextsAverage=0.0, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
      2011-06-30 10:07:18,343 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=600.025, TotalContexts=0, ErrorCount=0, ContextsPerSecond=0.0, AverageContextSeconds=0.0, LongestContextSeconds=0.0, AverageActiveContexts=0.0, MaxActiveContexts=0
      2011-06-30 10:07:18,343 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=600.025, TotalContexts=0, ErrorCount=0, ContextsPerSecond=0.0, AverageContextSeconds=0.0, LongestContextSeconds=0.0, AverageActiveContexts=0.0, MaxActiveContexts=0
      2011-06-30 10:07:24,091 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=128337984, NonHeapMemoryUsage=141835168, Uptime=1965556, ProcessCpuTime=90328125000, JITCTime=43231, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[3001,771], GCCount=[5,9], Classes=15457, Threads=48, TotalStartedThreadCount=271, PermGenPercentCollUsage=31.819297790527344, PermGenPercentUsage=31.819297790527344
      2011-06-30 10:07:36,117 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.002928585, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:07:36,769 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.000992584, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:07:39,637 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=1.0, ActiveSessionsMax=1, ActiveSessionsStart=1, ActiveSessionsEnd=1, ElapsedSeconds=600.000988952, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:07:40,301 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.001953321, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:17:18,208 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.00292607, CompletedContexts=9, ErrorCount=0, RedirectCount=0, ContextSecondsAverage=0.009695335333333334, ContextSecondsMax=0.013627151, ContextCpuSecondsAverage=0.005208333333333333, ContextUserSecondsAverage=0.003472222222222222, ContextJDBCConnWaitSecondsAverage=7.449777777777777E-6, ActiveContextsAverage=1.0001454293207728, ActiveContextsMax=2, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=0.0, PercentageOfContextTimeInJDBCCalls=0.0, PercentageOfContextTimeInJDBCConnWait=0.0768387840301392, PercentageOfContextTimeInJNDICalls=0.0
      2011-06-30 10:17:18,306 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=600.024, CompletedContexts=1, ErrorCount=0, ContextSecondsAverage=0.063231779, ContextSecondsMax=0.063231779, ContextCpuSecondsAverage=0.0, ContextUserSecondsAverage=0.0, ActiveContextsAverage=1.0543329933469328E-4, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
      2011-06-30 10:17:18,368 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=600.025, TotalContexts=1, ErrorCount=0, ContextsPerSecond=0.0016665972251156203, AverageContextSeconds=0.002426286, LongestContextSeconds=0.002426286, AverageActiveContexts=4.038053414441065E-6, MaxActiveContexts=1
      2011-06-30 10:17:18,368 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=600.025, TotalContexts=4, ErrorCount=0, ContextsPerSecond=0.006666388900462481, AverageContextSeconds=0.0064457915, LongestContextSeconds=0.01165204, AverageActiveContexts=4.2947802174909384E-5, MaxActiveContexts=1
      2011-06-30 10:17:24,769 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=128632808, NonHeapMemoryUsage=141871304, Uptime=2566234, ProcessCpuTime=91515625000, JITCTime=43324, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[3639,777], GCCount=[6,10], Classes=15303, Threads=48, TotalStartedThreadCount=343, PermGenPercentCollUsage=31.820695877075195, PermGenPercentUsage=31.820695877075195
      2011-06-30 10:17:36,142 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.001936279, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:17:36,793 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.00094174, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:17:39,661 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=0.43665361781295925, ActiveSessionsMax=1, ActiveSessionsStart=1, ActiveSessionsEnd=0, ElapsedSeconds=600.001004597, SessionsCreated=0, SessionsDestroyed=1, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:17:40,327 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.002866007, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:20:04,014 ERROR [TP-Processor6] org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill] - Session event listener threw exception
      ... 80 more
      2011-06-30 10:20:04,113 ERROR [TP-Processor6] com.ptc.windchill.enterprise.navigation - Can't find WTUser on Session
      at sun.reflect.GeneratedMethodAccessor154.invoke(Unknown Source)
      2011-06-30 10:20:04,139 ERROR [TP-Processor6] com.ptc.jca.navigation - problem getting the main navigation action model
      2011-06-30 10:20:04,168 ERROR [TP-Processor6] com.ptc.windchill.uwgm.common.container.ContainerUtilities - ContainerUtilities.getOrgContainerOfSessionUser :: (wt.session.sessionResource/2) wt.org.UserNotFoundException: User not found: unknown web name: "wcadmin".
      2011-06-30 10:20:04,224 WARN [TP-Processor6] com.ptc.windchill.uwgm.common.prefs.UwgmPreferences - UwgmPreferencesImpl.<init> :: Cannot obtain a principal from Session
      2011-06-30 10:20:05,090 ERROR [TP-Processor6] com.ptc.core.components.jsp.JspUtils - wt.util.WTRuntimeException: wt.util.WTException: java.lang.reflect.InvocationTargetException
      ... 60 more
      2011-06-30 10:20:05,094 ERROR [TP-Processor6] wt.method.MethodContextMonitor.contexts.servletRequest - 2011-06-30 14:20:04.990 +0000, 1br44s1;gpjrari4;4944;pot4xk;155, -, -, 1br44s1;gpjrari4;4944;pot4xk;154, wcadmin, 172.27.8.49, -, -, , 0, 0, 0.018287799, 0.078125, 0.104102058
      ... 40 more
      ... 54 more
      ... 55 more
      ... 60 more
      2011-06-30 10:20:05,099 ERROR [TP-Processor6] wt.servlet.ServletRequestMonitor.request wcadmin - 2011-06-30 14:20:04.989 +0000, 1br44s1;gpjrari4;4944;pot4xk;154, wcadmin, 172.27.8.49, /Windchill/netmarkets/jsp/util/clearDynamicAttributes.jsp, dynamicFlush=true, POST, 302, 0.078125, 0.10924964
      ... 60 more
      2011-06-30 10:20:05,102 ERROR [TP-Processor6] org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill].[jsp] - Servlet.service() for servlet jsp threw exception
      2011-06-30 10:20:54,299 ERROR [TP-Processor6] com.ptc.windchill.enterprise.navigation - Can't find WTUser on Session
      2011-06-30 10:20:54,335 ERROR [TP-Processor6] com.ptc.jca.navigation - problem getting the main navigation action model
      2011-06-30 10:20:54,362 ERROR [TP-Processor6] com.ptc.windchill.uwgm.common.container.ContainerUtilities - ContainerUtilities.getOrgContainerOfSessionUser :: (wt.session.sessionResource/2) wt.org.UserNotFoundException: User not found: unknown web name: "wcadmin".
      2011-06-30 10:20:54,416 WARN [TP-Processor6] com.ptc.windchill.uwgm.common.prefs.UwgmPreferences - UwgmPreferencesImpl.<init> :: Cannot obtain a principal from Session
      2011-06-30 10:27:18,212 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.002875505, CompletedContexts=20, ErrorCount=1, RedirectCount=0, ContextSecondsAverage=0.0686644114, ContextSecondsMax=0.56087324, ContextCpuSecondsAverage=0.053125, ContextUserSecondsAverage=0.04765625, ContextJDBCConnWaitSecondsAverage=7.68113E-5, ActiveContextsAverage=1.0022888027442272, ActiveContextsMax=3, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=1.4, PercentageOfContextTimeInJDBCCalls=4.737835122547923, PercentageOfContextTimeInJDBCConnWait=0.11186479055728132, PercentageOfContextTimeInJNDICalls=7.608060265117193
      2011-06-30 10:27:18,309 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=600.003, CompletedContexts=28, ErrorCount=0, ContextSecondsAverage=0.013785032142857144, ContextSecondsMax=0.036739865, ContextCpuSecondsAverage=0.010044642857142858, ContextUserSecondsAverage=0.008370535714285714, ActiveContextsAverage=6.442062156355885E-4, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
      2011-06-30 10:27:18,372 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=600.004, TotalContexts=28, ErrorCount=0, ContextsPerSecond=0.046666355557629616, AverageContextSeconds=0.003731449857142857, LongestContextSeconds=0.021023063, AverageActiveContexts=1.7395530863127578E-4, MaxActiveContexts=1
      2011-06-30 10:27:18,372 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=600.004, TotalContexts=0, ErrorCount=0, ContextsPerSecond=0.0, AverageContextSeconds=0.0, LongestContextSeconds=0.0, AverageActiveContexts=0.0, MaxActiveContexts=0
      2011-06-30 10:27:25,400 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=132424232, NonHeapMemoryUsage=142085512, Uptime=3166864, ProcessCpuTime=93921875000, JITCTime=43513, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[4245,797], GCCount=[7,11], Classes=15315, Threads=50, TotalStartedThreadCount=416, PermGenPercentCollUsage=31.857866287231445, PermGenPercentUsage=31.857866287231445
      2011-06-30 10:27:36,143 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.001942426, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:27:36,794 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.001968127, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:27:39,662 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=0.7594984147845913, ActiveSessionsMax=1, ActiveSessionsStart=0, ActiveSessionsEnd=1, ElapsedSeconds=600.001895493, SessionsCreated=1, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:27:40,327 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.000996495, CompletedRequests=5, ErrorCount=0, RequestSecondsAverage=0.20886777539999998, RequestSecondsMax=0.561732567, RequestCpuSecondsAverage=0.184375, RequestUserSecondsAverage=0.165625, ActiveRequestsAverage=0.0017436442241120815, ActiveRequestsMax=1, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:32:27,073 ERROR [TP-Processor6] org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill] - Session event listener threw exception
      ... 80 more
      2011-06-30 10:32:27,102 ERROR [TP-Processor6] com.ptc.windchill.enterprise.navigation - Can't find WTUser on Session
      2011-06-30 10:32:27,127 ERROR [TP-Processor6] com.ptc.jca.navigation - problem getting the main navigation action model
      2011-06-30 10:32:27,151 ERROR [TP-Processor6] com.ptc.windchill.uwgm.common.container.ContainerUtilities - ContainerUtilities.getOrgContainerOfSessionUser :: (wt.session.sessionResource/2) wt.org.UserNotFoundException: User not found: unknown web name: "wcadmin".
      2011-06-30 10:32:27,207 WARN [TP-Processor6] com.ptc.windchill.uwgm.common.prefs.UwgmPreferences - UwgmPreferencesImpl.<init> :: Cannot obtain a principal from Session
      2011-06-30 10:32:28,075 ERROR [TP-Processor6] com.ptc.core.components.jsp.JspUtils - wt.util.WTRuntimeException: wt.util.WTException: java.lang.reflect.InvocationTargetException
      ... 60 more
      2011-06-30 10:32:28,080 ERROR [TP-Processor6] wt.method.MethodContextMonitor.contexts.servletRequest - 2011-06-30 14:32:27.919 +0000, 1br44s1;gpjrari4;4944;pot4xk;221, -, -, 1br44s1;gpjrari4;4944;pot4xk;220, wcadmin, 172.27.8.49, -, -, , 0, 0, 0.045804983, 0.046875, 0.160658128
      ... 40 more
      ... 54 more
      ... 55 more
      ... 60 more
      2011-06-30 10:32:28,086 ERROR [TP-Processor6] wt.servlet.ServletRequestMonitor.request wcadmin - 2011-06-30 14:32:27.918 +0000, 1br44s1;gpjrari4;4944;pot4xk;220, wcadmin, 172.27.8.49, /Windchill/netmarkets/jsp/util/clearDynamicAttributes.jsp, dynamicFlush=true, POST, 302, 0.0625, 0.16632924
      ... 60 more
      2011-06-30 10:32:28,089 ERROR [TP-Processor6] org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill].[jsp] - Servlet.service() for servlet jsp threw exception
      2011-06-30 10:37:18,174 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.001051251, CompletedContexts=16, ErrorCount=1, RedirectCount=0, ContextSecondsAverage=0.07056661525, ContextSecondsMax=0.454589899, ContextCpuSecondsAverage=0.03515625, ContextUserSecondsAverage=0.03125, ContextJDBCConnWaitSecondsAverage=6.81825E-5, ActiveContextsAverage=1.0018817731096403, ActiveContextsMax=3, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=1.8125, PercentageOfContextTimeInJDBCCalls=5.495823235619906, PercentageOfContextTimeInJDBCConnWait=0.09662146860586458, PercentageOfContextTimeInJNDICalls=11.826327641525927
      2011-06-30 10:37:18,271 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=599.962, CompletedContexts=18, ErrorCount=0, ContextSecondsAverage=0.023254274555555555, ContextSecondsMax=0.126110163, ContextCpuSecondsAverage=0.012152777777777778, ContextUserSecondsAverage=0.009548611111111112, ActiveContextsAverage=6.983359596107753E-4, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
      2011-06-30 10:37:18,336 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=599.964, TotalContexts=19, ErrorCount=0, ContextsPerSecond=0.03166856678067351, AverageContextSeconds=0.004408602157894737, LongestContextSeconds=0.016325538, AverageActiveContexts=1.3950189178017346E-4, MaxActiveContexts=1
      2011-06-30 10:37:18,336 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=599.964, TotalContexts=10, ErrorCount=0, ContextsPerSecond=0.016667666726670267, AverageContextSeconds=0.0049763585, LongestContextSeconds=0.017883557, AverageActiveContexts=8.289260022268002E-5, MaxActiveContexts=1
      2011-06-30 10:37:26,229 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=110676024, NonHeapMemoryUsage=140394872, Uptime=3767693, ProcessCpuTime=96625000000, JITCTime=44368, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[5099,805], GCCount=[8,12], Classes=15337, Threads=50, TotalStartedThreadCount=488, PermGenPercentCollUsage=31.436979293823242, PermGenPercentUsage=31.436979293823242
      2011-06-30 10:37:36,107 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.001965892, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:37:36,757 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.001903873, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:37:39,624 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=1.5211827005090472, ActiveSessionsMax=2, ActiveSessionsStart=1, ActiveSessionsEnd=2, ElapsedSeconds=600.000998171, SessionsCreated=1, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:37:40,291 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.002893385, CompletedRequests=4, ErrorCount=0, RequestSecondsAverage=0.1652207195, RequestSecondsMax=0.455365417, RequestCpuSecondsAverage=0.1015625, RequestUserSecondsAverage=0.08984375, ActiveRequestsAverage=0.001102447648657517, ActiveRequestsMax=1, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:41:01,825 ERROR [IE-org.jabil.corp.corcedev02.Windchill-Processor-0] com.infoengine.log.error - Connection reset
      2011-06-30 10:47:18,197 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.method.MethodContextMonitor.stats.summary - ElapsedSeconds=600.002848128, CompletedContexts=12, ErrorCount=0, RedirectCount=0, ContextSecondsAverage=0.136952555, ContextSecondsMax=0.610418922, ContextCpuSecondsAverage=0.11067708333333333, ContextUserSecondsAverage=0.045572916666666664, ContextJDBCConnWaitSecondsAverage=3.561916666666667E-6, ActiveContextsAverage=1.002739038098115, ActiveContextsMax=3, ActiveContextsStart=1, ActiveContextsEnd=1, AverageJDBCCallsPerContext=0.0, AverageJNDICallsPerContext=0.6666666666666666, PercentageOfContextTimeInJDBCCalls=0.0, PercentageOfContextTimeInJDBCConnWait=0.0026008398796697634, PercentageOfContextTimeInJNDICalls=2.4503232159487642
      2011-06-30 10:47:18,291 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.util.IeContextMonitor.stats.summary - ElapsedSeconds=600.02, CompletedContexts=4, ErrorCount=0, ContextSecondsAverage=0.40181447675, ContextSecondsMax=0.652439067, ContextCpuSecondsAverage=0.33984375, ContextUserSecondsAverage=0.14453125, ActiveContextsAverage=0.002679110147995067, ActiveContextsMax=0, ActiveContextsStart=0, ActiveContextsEnd=0
      2011-06-30 10:47:18,358 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=org.jabil.corp.Ldap, IntervalSeconds=600.022, TotalContexts=1, ErrorCount=0, ContextsPerSecond=0.001666605557796214, AverageContextSeconds=0.009598985, LongestContextSeconds=0.009598985, AverageActiveContexts=1.5991668638816576E-5, MaxActiveContexts=1
      2011-06-30 10:47:18,358 INFO [wt.jmx.core.SharedScheduledExecutor.worker] com.infoengine.jndi.DirContextMonitor.stats.summary - ServiceName=com.infoengine.au.DirectoryService, IntervalSeconds=600.022, TotalContexts=8, ErrorCount=0, ContextsPerSecond=0.013332844462369712, AverageContextSeconds=0.005033670375, LongestContextSeconds=0.023251559, AverageActiveContexts=6.707682884960884E-5, MaxActiveContexts=1
      2011-06-30 10:47:27,021 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=4944@CORCEDEV02, HeapMemoryUsage=112124696, NonHeapMemoryUsage=140797528, Uptime=4368486, ProcessCpuTime=99828125000, JITCTime=44774, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[5856,812], GCCount=[9,13], Classes=15390, Threads=48, TotalStartedThreadCount=559, PermGenPercentCollUsage=31.548467636108395, PermGenPercentUsage=31.55361557006836
      2011-06-30 10:47:36,132 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill-WHC, ActiveSessionsAverage=0.0, ActiveSessionsMax=0, ActiveSessionsStart=0, ActiveSessionsEnd=0, ElapsedSeconds=600.001933207, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:47:36,781 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill-WHC, ElapsedSeconds=600.001000407, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
      2011-06-30 10:47:39,649 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.SessionMonitor.stats.summary - ContextPath=/Windchill, ActiveSessionsAverage=2.0, ActiveSessionsMax=2, ActiveSessionsStart=2, ActiveSessionsEnd=2, ElapsedSeconds=600.000955988, SessionsCreated=0, SessionsDestroyed=0, SessionsActivated=0, SessionsPassivated=0
      2011-06-30 10:47:40,316 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.servlet.ServletRequestMonitor.stats.summary - ContextPath=/Windchill, ElapsedSeconds=600.001030019, CompletedRequests=0, ErrorCount=0, RequestSecondsAverage=NaN, RequestSecondsMax=0.0, RequestCpuSecondsAverage=NaN, RequestUserSecondsAverage=NaN, ActiveRequestsAverage=0.0, ActiveRequestsMax=0, ActiveRequestsStart=0, ActiveRequestsEnd=0
